Old 11-08-2022, 11:51 AM   #1
ECS Coil overs
Hi All. I purchased and had installed the ECS Coil overs. They dropped the car quite a bit , so not to bottom out, the installer set the softness to max and spring pre-load to the tightest available (all the way to the top). As a result, the car now bounces over smallest of bumps. Has anyone installed the same coil overs and if so, what settings did you use? Please help.
2000 Boxster S (986)
De-snorkeled withK&N Cold Air intake
Short Shifter 14mm spacers F&B
Secondary Cat delete
Top Speed Test pipes and Exhaust
NJBoxster2000 is offline   Reply With Quote
Old 11-08-2022, 01:14 PM   #2
Sounds like you need to increase the rebound and compression settings if the coil overs have both capabilities
Old 11-09-2022, 01:04 PM   #3
NJBoxter, usually the coilovers come with the installation instructions and there you will find the 'MFR suggested starting point', from there is trial and error to get them to your like.
Keeping in mind that you should do a single 'small' adjustment at the time and document in writing your observations, then if you have to remove them to make a repair on your suspension, you will not have to start from scratch again.
Old 11-10-2022, 06:23 PM   #4
Share pics please. I want to see what "spring pre-load to the tightest available (all the way" looks like. That sounds like a terrible idea, unless you like coil bind.
Sent from my SM-G781W using Tapatalk
JDMsurprise is offline   Reply With Quote
Tags
ecs coil overs
