Old 06-14-2022, 02:25 PM   #1
Check engine code
2001 Boxster S, I got the following trouble code with my Foxwell scanner: P0430/$11 “ Catalyst system efficiency below threshold bank 2”. I understand that this is an O2 sensor, but which one.? Thanks
Barcalude is offline   Reply With Quote
Old 06-14-2022, 02:44 PM   #2
It may not be the O2 sensor, that code is specific to the performance of the cat.
Old 06-14-2022, 08:48 PM   #3
Like JFP mentioned, the code is most likely related to the cat performance.
Bank 2 is on driver side at the Boxster (left hand side driven cars). This means that it would be the later O2 sensor on bank 2 that sniffs the cat problem.
2001 996 C2 Manual
pilot4fn is online now   Reply With Quote
Old 06-15-2022, 04:53 AM   #4
1998 Boxster Silver/Red
So then... it could be the sensor and it's not sniffing properly? Or, as JFP said... cat problem. One or the other? Thanks.
1998 Porsche Boxster
Old 06-15-2022, 02:32 PM   #5
Easy enough to find out, check the sensor electrically, if it is working, it ain’t the sensor.
Old 06-16-2022, 05:47 PM   #6
The front O2 sensor only reports what it is receiving and the rear one likewise reports how well the cat did its job. The problem may be upstream. The air mass may not be sensed correctly, the throttle body may not be reacting promptly, the injectors may not be operating correctly and thus the air/fuel mix is not correct, doesn't get burned and dumps too much unburned stuff into the cat for the cat to absorb.
So lets start...it is an '01 base or S? How many miles. Otherwise running OK? What tool did you use to pull the codes? Any others showing? Any recent work anywhere in the engine bay? Is the air pump that adds O2 just after startup working? Any hose leaks?
Prior '70 914, '99 986 Boxster, '01 Boxster S
