Old 01-12-2022, 08:41 AM   #1
Simple solution for oil filter removal
Just fix 2 medium jubilee type clips (the ones with a flat worm drive) around the filter housing right at the top near the aluminium casting and tighten quite tightly.
Tap one of the screw heads with a hammer sharply to loosen the over tightened housing slightly, then spin it off with your hand.
trevorhp is offline   Reply With Quote
Old 01-12-2022, 08:57 AM   #2
LN Engineering spin on filter adapter
2ata is offline   Reply With Quote
Old 01-12-2022, 10:13 AM   #3
Or just use the correct tool instead of a hammer
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 01-12-2022, 12:07 PM   #4
Let's see: Tighten a steel band clamp around a brittle plastic housing full of oil, then hit it with a hammer. I'd suggest if you intend to go this route, have lots of oil spill cleanup supplies on hand, as well as a replacement canister. Or as suggested, just get the right tool in the first place...........
Old 01-12-2022, 04:26 PM   #5
elgyqc's Avatar
/img]
I like original and inexpensive solutions... this could work. I have the proper tool but it cost over $30. For removing the filter once a year your idea is cost effective. I think there is a difference between tapping with hammer to loosen and hammering...
Grant
Old 01-12-2022, 05:01 PM   #6
Why are we overthinking this? I just use one of those cheap stamped-steel oil filter tools with no problem.
Old 01-13-2022, 01:33 PM   #7
I recently acquired a 2001 Boxster S which still had the plastic oil filter can. It was on so tight that my Hazet oil filter wrench would ‘cam over’ at approximately 175 foot-pounds of torque. The cast-aluminum cap type wrench sold as ‘Craftsman’ at Lowe’s saved the day, and I was able to get the plastic cup off the engine, but I couldn’t get the tool off the cup.
My suggestion: under NO circumstance should you continue use of the plastic cup, and risk having either a permanently-installed oil filter, or worse, having the cup break off at its threads. Good luck removing the fragments. The aluminum spin-on adapter and filer should be fitted at the time the car is acquired.
Notice the M96 engine blocks for sale on eBay: they all still have the black filter cup in place. The sellers couldn’t get them off!
old911doc is offline   Reply With Quote
Old 01-13-2022, 02:27 PM   #8
actually it's most likely not cause they couldnt get it off, it's cause they dont even bother. They will drain the oil but leave filters on so oil doesn't come out holes when getting moved around or shipped. Not to mention then they have to dispose of them.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 01-13-2022, 04:09 PM   #9
Oh My Gosh! What is it with these dealerships and shops whose employees crank on the oil filters with lug nut-level (or higher) torques! Hand tightening, it works. In over 80k worth of oil changes (@ every 3-4k miles) I have, after hand tightening, had one single solitary occasion where I got the slightest seepage and had to tighten it a smidgen more. The oil loss was infinitesimal—didn't have to top it off a drop.
And yeah, get the spin-on oil filter adapter. A definite upgrade.
Old 01-14-2022, 09:22 AM   #10
1997 Tip, 2018 Macan
rexcramer's Avatar
My guess is most people never use their torque wrench (set at 19lbs I believe) to re-install the plastic oil housing. Most of them are/have been ridiculously over-tightened.
