Old 07-27-2021, 08:02 PM   #1
Engine wiring
Anyone ever replace the engine wiring harness? If so, anyone ever done it with the engine IN the car?
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 07-28-2021, 06:29 AM   #2
Definitely not the easiest thing in the world to do with the engine in...............
Old 07-28-2021, 03:22 PM   #3
Trust me, you don't want to do that. I tried, and resorted to dropping the engine. It is so much easier access.
-H. L. Mencken
Old 07-28-2021, 03:23 PM   #4
I know, but was trying to be lazy about it. Might have the shop just do it when they do a couple other things on it.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 07-28-2021, 03:38 PM   #5
If you are paying a shop to do it, and they don't drop the engine, the cost just in labor time is going to skyrocket................
Old 07-28-2021, 03:45 PM   #6
I expect they will drop it if I have them do it
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 07-28-2021, 07:26 PM   #7
In my experience it comes down to just that....experience. If you have removed a harness from an engine that was out of the car, then you know how it was run and where the "hidden" connectors are and with that knowledge you can work around in the engine bay - assuming access above, below and through firewall - to change out the harness with the motor in the car.
Are you working with a 2.7 out of a 2000? I ask because I once took a 2.7 out of a 2000 and tried to drop in a 2001 2.7 into that 2000. The wiring harness from the 2001 would not work seamlessly with the 2000 computers. One problem was the temperature sensor in the 2000 had four prongs, whereas the 01 had a two prong connector. A second problem was with the tiptronic thumb shifter not working. Once I took the harness off the 2000 2.7 and put it on the 01 2.7 everything worked fine again in the 2000.
Good luck
Xcellr8 is offline   Reply With Quote
