Old 05-31-2021, 03:33 PM   #1
topping off coolant
How often (if ever) should I be topping off my coolant?
I drive my 98 boxster with 85k miles a few times a week for 20-30 minute runs.
The coolant light blinks every 3-4 months and I add 4-8oz of coolant or water to make the light go off.
I don't see any coolant leaking on the floor and I don't smell anything like burning coolant not do I have white smoke on startup.
It is normal to have to top off the coolant like this? From what I gather it is not. What could some potential problems be that I can check?
I am considering driving this car cross country later this summer and I want everything attended to that can break so I am planning extensive maintenance on it: AOS, coils, plugs, injectors, sensors, filters, oil.
pianoporsche is offline   Reply With Quote
Old 05-31-2021, 04:11 PM   #2
Short answer no.
The coolant tank in the trunk are a know problem with these cars.
They get hairline cracks with age. Then they leak while under pressure.
Pull the carpet and the sub floor, everything tell you are down to steel in the trunk floor. Look for signs of coolant and coolant smell in the trunk.
A coolant pressure test to diagnose the issue would also be a good idea.
Either have a shop do it or go to Harbour Frieght and but a coolant pressure test kit.
they are around $90.00 works on any coolant system you can also test the coolant cap with them.
Old 05-31-2021, 08:10 PM   #3
If you don't know when the coolant tank was last replaced, I would just replace it. They go in a very sneaky way, then strand you. Been there, done that.
-H. L. Mencken
Old 06-01-2021, 06:38 AM   #4
2003 S, Arctic Silver, M6
paulofto's Avatar
Best advise I can give is check your coolant cap is the newest available with the part number ending in 04. Older caps are know to fail, some suddenly, and spilling coolant well below the pressure desired. Yours might be releasing vapour and you may never see actual liquid.
Old 06-02-2021, 03:46 AM   #5
Hi buddy,
How to top off coolant: Key Steps
Step 1: Don't use your right before. ...
Step 2: Open the hood and locate the coolant reservoir. ...
Step 3: Assess the coolant level. ...
Step 4: Mix coolant and water. ...
Step 5: Top off the radiator. ...
Step 6: Top off the coolant reservoir.
Check out our beautiful website if you are interested in cars and <a href="https://cash-cars.sydney/cash-for-old-car-in-sydney/">old car</a>.
akbaradeli is offline   Reply With Quote
Old 06-02-2021, 05:57 AM   #6
Originally Posted by akbaradeli View Post
Hi buddy,
This is a 986, there is no way to top off the radiator and the reservoir is in the trunk not the hood.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 06-02-2021, 03:21 PM   #7
1998 Boxster Owner
http://986forum.com/forums/boxster-general-discussions/80719-coolant-overflow.html
Benitom is offline   Reply With Quote
Old 06-02-2021, 03:47 PM   #8
Since I did not see any wetness on the carpet in the trunk I figured that the coolant tank was not leaking. (I assumed that the carpet sat on the metal floor of the trunk.)
I did a little more digging and realized that there is a particle board sub-floor in the trunk. I removed the carpet and looked at that and saw that it was all swollen with- presumably- coolant.
See this picture of the particle board sub-floor that sits in the right hand (passenger) side of the trunk. It is swollen in many places.
The piece on the left is the left particle board sub-floor that sits in the left hand side of the trunk. Not swollen. The main particle board sub-floor (not shown) was not affected.
So, yes I guess my coolant tank is leaking.
I will not go ahead and replace it.
I am also going to change the oil and plugs to make sure the coolant isn't leaking from the engine block just to be sure.
Thank you for all your help.
Old 06-02-2021, 05:09 PM   #9
Yep that's why I said take out the sub floor and take it down to the metal trunk floor.
For sure and issue with the tank. Time to replace it.
Some people struggle with replacing the tank.
I didn't find it that big of a deal.
I removed the suspension triangle and went at the hoses from below.
There is lots of info on replacing it here on the forum.
Just use the search feature.
