Old 11-03-2006, 11:57 AM   #1
Send a message via AIM to blinkwatt
Fasteners are really stuck on
Im in the middle of removing the fasteners from the diagonal brace to perform a tranny oil change. They seem really stuck on,anyone have a hint on how to loosen them up?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 11-03-2006, 12:05 PM   #2
Got'em loose. WD-40 and a breaker bar!
Old 11-03-2006, 12:05 PM   #3
Hi,
Try tapping them lightly, and carefully, with a Hammer. Also, use a penetrant, I prefer PB Blaster (available at most auto stores). It uses enzymes to literally eat through any corrosion, spray on and let it work for an hour or 2. There could be road debris (oil, mud, Tar, etc.) clogging the threads on the backside of the diagonals, try a small wire brush to clean the threads if you can reach them.
Also, if you have a Breaker Bar, the added length will give you a better mechanical advantage than a 6" Ratchet Handle would. Hope this helps...
Happy Motoring!... Jim'99
Old 11-03-2006, 12:06 PM   #4
Hi,
Great Minds... Good Luck!...
Old 11-03-2006, 12:18 PM   #5
Send a message via MSN to CJ_Boxster
What brand of gear oil are you using?
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 11-03-2006, 02:47 PM   #6
Redline MT90. Almost done(I stopped to eat and watch part of Scarface).
