Old 03-21-2021, 02:36 PM   #1
Every gear is neutral 🤬
Just driving around, all of sudden my 2001 Porsche boxster S decides to make a weird lil noise try to put it in 2nd and nothing. Put it in any gear and it feels like neutral. Clutch feels the same ???!!!??!!!
Please help
GBNATTYDADDY is offline   Reply With Quote
Old 03-21-2021, 04:03 PM   #2
Please help
Check the cable connections at the transmission. The shift cables from the shifter are connected to and move two levers on the side of your transmission. They fail.
If no problem there then check the cable connections at the shifter.
Keep us posted let us know what you find.
Old 03-21-2021, 05:58 PM   #3
husker boxster's Avatar
The technical term is "hand fulla neutrals".
Blue62 has sent you in the proper direction.
1989 928 S4 5 spd - black
Old 03-22-2021, 01:13 PM   #4
take a look at your drive shafts..
this could be a sign of a CV joint (axle) that failed..
Old 03-22-2021, 06:57 PM   #5
Had something like this happen to me a couple months ago, in my case the CV joints were the issue
A_NeonTurtle is offline   Reply With Quote
Old 03-24-2021, 10:17 AM   #6
U guys r awesome!!! So I got it towed to my cousin's house to get fixed. Somehow the gears work for a little bit at his house and he drove it down the road and it went out again. It was the driver's side cv joint/axle whatever. So he's replacing both of them. Any suggestions on a reasonable not stupid sounding exhaust!?!?
Thanks again!!!
Tags
clutch , gears , manual
