Old 07-06-2020, 08:01 AM   #1
Ignition Switch Replacement
Hi All, I replaced my ignition switch yesterday and now the key goes in easily but doesn't turn.
I replaced the ignition switch because the key sometimes wouldn't come out or go in. Also lights would stay on with key out of ignition etc..
You think the new switch I got is defective? I bought off of amazon should I buy from Audi dealer for better quality?
Thanks in advance
Boxster33 is offline   Reply With Quote
Old 07-06-2020, 08:22 AM   #2
1998 Boxster Silver/Red
Did you purchase OEM?
Certain of your dash lights will remain on for ~10-15 minutes after the key is removed.
Did you jiggle the steering wheel? If the key was removed from the ignition when the wheels weren't set straight the key can be met with some resistance.
Report back!!
1998 Porsche Boxster
Old 07-06-2020, 09:44 AM   #3
Yea, I tried moving steering wheel but no luck. I even put the old ignition switch back in and same issue. Can a weak battery cause the same symtoms? The dash doesn't light up only a red light on stereo blinks on and off.
Old 07-06-2020, 10:53 AM   #4
Forgot to mention that this part i used:
https://www.amazon.ca/gp/product/B0066SFYMO/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Old 07-06-2020, 11:04 AM   #5
Porsche "Purist"
Paul's Avatar
With the electrical part removed, does the key turn?
1987 924S. 2002 996TT. PST-2
Old 07-06-2020, 11:08 AM   #6
You mean try to turn the key after removing the Ignition switch?
Old 07-06-2020, 11:30 AM   #7
Porsche "Purist"
Paul's Avatar
Yes, I'm guessing your problem is the steering lock assembly.
Old 07-06-2020, 12:20 PM   #8
Driving home fron the casino Saturday night (after the LIVE show!!) my wife said, "Why is the stereo blinking?". I watched it... three flashes.. two flashes... three flashes... then it stopped just as soon as it had started.
Hmmmmmmmm. Wonder if my ignition switch is going out?
May have to buy the part just in case. Thabnks for the heads-up!
Old 07-07-2020, 07:14 AM   #9
Issue is resolved. I removed the ignition switch then pulled on steering wheel to unlock steering assembly and reinstalled switch. Works perfectly.
