Old 06-04-2020, 12:04 PM   #1
Front hood struts replacement
I need to replace the hood struts on the frunk lid. How does one remove the old ones? Do they just 'pop off' using some sort of lever or is there something else that I need to do?
Harry
1970 911T Hot Rod
2003 Boxster S
2018 Macan S
2021 718 Spyder
Balloonmeister is offline   Reply With Quote
Old 06-04-2020, 12:27 PM   #2
Beelzy's Avatar
There should be a tiny latch or cover over the ball end that you pry up first to get access for removal.
Beelzy is offline   Reply With Quote
Old 06-04-2020, 01:01 PM   #3
1997 Tip, 2018 Macan
rexcramer's Avatar
https://www.youtube.com/watch?v=r1aS86Wv_ZM
Old 06-04-2020, 01:01 PM   #4
Thank you!
Harry
1970 911T Hot Rod
2003 Boxster S
2018 Macan S
2021 718 Spyder
Old 06-04-2020, 01:05 PM   #5
JayG's Avatar
Brute force and ignorance works every time LOL
Old 06-04-2020, 01:31 PM   #6
1998 Boxster Silver/Red
Definately a dealer event. Maybe an indy if you can find one who wants to tackle that project. Good luck.
1998 Porsche Boxster
Old 06-04-2020, 02:23 PM   #7
TRP
WHAT!? Oh wait... maybe sarcasm?
I ordered mine through one of the suppliers and swapped them out in 2 minutes. The video above is a good approach. I was mildly horrified with how he removed the clips. Maybe his clips were different than mine? My clips slide out towards the ends.
Do one side at a time.
On each end of the strut there is a metal clip which slides up (toward the 'end' of the ball) in a little groove. I put a small thin screwdriver under the edge and wiggled/slid that clip out toward the end of the ball. If you slide the clip too far it will slip off the ball. Not a huge deal, just keep an eye on where it lands.
You will need to move the little clips for both the old ones (that are on the car) and the new ones (that will be in your hand).
Once you slide the clips over a bit then you can pull the strut off of the ball. With one hand, hold up the bonnet / hood with the other pull the end off the ball. Top or bottom first then the other end. You can see how in the video he has to 'whack' the strut a bit. For the struts on my 2000, if you slide the clips off properly you don't need to do that. The struts just come off really easily. Once that's off... put the 'new one' on. This is where it's handy if you've already moved the clips on the new ones. Slip the ends over the ball end and then slide the cover / retainer clip back into the starting position. In the video above, the mechanic just pushes the new ones over the ball end without moving the clips. I don't know if there is anything wrong with that.
Do the other side. Now you're done.
If you go to the dealer for this... :troll:
TRP is offline   Reply With Quote
Old 06-04-2020, 04:24 PM   #8
JayG's Avatar
Yea, what he said
Definitely a DIY. Don't waste your $$ at a dealer on hood struts
Old 06-05-2020, 04:47 AM   #9
Yes. I was being sarcastic. I'll do that once in a while.
Old 06-05-2020, 07:31 AM   #10
Wow, Starter986, I almost had made that appointment with the dealer. Luckily, I saw the post with the YouTube video and I was actually able to do the job all by myself. Saved lots of money.
Thanx to all (including Starter ), who responded.
Harry
1970 911T Hot Rod
2003 Boxster S
2018 Macan S
2021 718 Spyder
Old 06-05-2020, 10:53 AM   #11
That was one of the first things I did when I got the car. Watched the YT vids... read from upon these pages.
You'll find elsewhere to spend that money.
See ya around!
Old 06-09-2020, 07:56 AM   #12
Just watch out for the clips when they pop off. Put a shop towel around it when you pop it out. Those thing can really fly, and you don’t want to drive over them.
Blackcloud is offline   Reply With Quote
