Old 05-14-2020, 07:14 PM   #1
98 boxster 986 wipers stopped working
Hi Everyone.
My wipers on my 98 986 stopped working suddenly. They don't move at all.
I don't have the intermittent feature so I think that there is no relay for them (as far as I can tell from the Bentley manual).
The fuse is fine.
The washers still work fine.
Is this pretty much a dead motor? Anything else to consider?
pianoporsche is offline   Reply With Quote
Old 05-14-2020, 08:15 PM   #2
A Porsche Guy
1PorscheBoxster986's Avatar
There is a relay for the wipers so that can be your problem. According to oldskool73 in this thread, he has a 97 so you should have it for your 98 as well. Factory wiper relay is 98661510300. It is pretty easy to locate and the relay is located above the fuse box underneath the driver side.
I changed it to a VW/Skoda one to get the intermittent feature last year based on his suggestion. It works and I'm happy. According to some with the intermittent wiper dial, this mod works better.
http://986forum.com/forums/diy-project-guides/60548-adding-variable-intermittent-wipers-early-box-easy-way-2.html
1PorscheBoxster986 is offline   Reply With Quote
Old 05-15-2020, 06:31 PM   #3
I'm confused . . . so is there a relay for non-intermittent wipers?
If so, where is it?
If I add the intermittent relay will my wipers work?
Old 05-15-2020, 09:12 PM   #4
Multi-Boxer Driver
Deserion's Avatar
They are all intermittent, but the upgrade is adding variability to that.
The relay is on the panel right above the dead pedal (LHD cars) it’s blue and on the third row from the top on the far right.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
