Old 02-07-2020, 11:34 PM   #1
convertible top maintenance position/ for glass
My 02' has a glass rear window therefore it will not fold up as the plastic ones do, is there a different procedure for a glass top ? Thanks Frank
flmont is offline   Reply With Quote
Old 02-08-2020, 06:59 AM   #2
Who's askin'?
maytag's Avatar
I've only ever touched the glass windowed cars, but I think it's the same:
raise the roof about halfway.
Disconnect the drip tray from the clips.
Disconnect the cables from their ball- mounts.
Lift the bottom / baack of the top up towards the front of the car. There's a "sweet-spot" where the top will fold above the glass window and allow the window to fit "upside down", basically right behind the seats.
Old 02-08-2020, 07:16 AM   #3
The OP has a replacement top with the narrow glass window for the three stay original plastic window top. He is absolutely right, it doesn't fold up fully when you use the procedure you outlined.
1941 Dodge Luxury Liner Coupe
Old 02-08-2020, 07:36 AM   #4
2003 Base 5-speed
grc0456's Avatar
This is one reason why - when replacing the top on a 986.1 (1997-2002) - it's a good idea to replace with a 986.2 (2003-2004) top with the four bow frame. It fits an allows you to put the top in full service position.
Old 02-08-2020, 08:38 AM   #5
I have the 3 bow top and the glass always hits the roll bar, and it does not like to fold up,..but I will try different positions to see if it will fold up..Thanks !
Old 02-08-2020, 05:18 PM   #6
I had this issue with an aftermarket top and found the solution was too tuck the glass window above the frame with the hood on the service position.
Nobbie is offline   Reply With Quote
Old 02-11-2020, 07:56 AM   #7
Thanks Nobbie,..it is the best/only way to to get it out of the way,..Frak
