Old 10-09-2006, 04:07 PM   #1
Did I buy the correct brake pad hardware kit?
After reading and learning for several months I finally take the plunge with a first post!
I have a 2003 Boxster non-S and bought two 996 front brake hardware kits from Smith Motorworks to use for the front and rear calipers. The part number is 996.351.959.01. The price was really good -- $26/kit on Ebay (auction 200000001655). Can someone confirm if this is the correct part for the front and rear because they emailed to say it may not be right.
This weekend the Pagid blues go on. Hopefully I don't get stuck half way because this is my daily driver. It looks easy enough but time will tell.
timothy is offline   Reply With Quote
Old 10-09-2006, 04:28 PM   #2
I can't confirm...however if anything you can still put your new pads on and re-use the brake hardware. Be sure to lube the hell out of the hardware with the anti seize stuff, and don't be afraid to use the anti-squeel stuff on the backing of the pads.
Last thing...goto Sears and pick up a brake pad spreader. Tt looks like a metal backing pad with a twisty knob.
This will save you a **************** load of time and is worth the $9.99
Good luck!
KRZ
http://x402.putfile.com/2/5800280187-thumb.jpg
Voghtland 30-50mm Coilovers
19x8.5 x 19x10 Forgline rims
Magnaflow Exhaust
KRZTACO is offline   Reply With Quote
Old 10-09-2006, 05:34 PM   #3
boggtown
Posts: n/a
I can concur with the brake pad spreader, but I used a ghetto method of pliers and the old brake pads, lol. I just put pliers in before I took the old pads out and spread it that way since the old pads are worthless anyway.
Old 10-09-2006, 05:53 PM   #4
The part number is not correct. Price is great, but not for the wrong kit...
Here's the correct part number - 996 352 959 01
Here's what it looks like - http://www.epiqautosport.com/pro_boxster_brake_pad_hardware_kit.php
Todd
2005 Boxster S - Atlas Grey/Black, PASM, Sport Chrono, Bose
2006 Infiniti M35 Sport
2007 Cadillac Escalade (tow vehicle with bling)
'00 Boxster - 2.7l w/FVD ECU tuning, Moton double adjustable suspension, custom stainless headers, lightweight flywheel, dual Magnaflow mufflers, 18" CCR wheels, 911 front brakes in front, Boxster front brakes in rear, full welded cage.
http://www.epiqautosport.com/images/epiqtoddavatar2.jpg
EPIQTodd is offline   Reply With Quote
Old 10-09-2006, 06:32 PM   #5
Hmm. I added the hardware kit to my "cart" on the Epiq Autosport website and the order page lists 99635195901s as the part number. 351 not 352.
Old 10-10-2006, 08:38 AM   #6
Smith Motorworks gets 5-stars in my book. The offered to cancel the order since I bought the wrong hardware kit. Thanks for the help. I'll definitely hit up Sears for a pad spreader.
- Timothy
