I can't confirm...however if anything you can still put your new pads on and re-use the brake hardware. Be sure to lube the hell out of the hardware with the anti seize stuff, and don't be afraid to use the anti-squeel stuff on the backing of the pads.
Last thing...goto Sears and pick up a brake pad spreader. Tt looks like a metal backing pad with a twisty knob.
This will save you a **************** load of time and is worth the $9.99
Good luck!
KRZ
