Old 10-09-2006, 02:30 PM   #1
Interior Light Problem
I have a 2000 that the inside lights all stay on all the time, (until the computer shuts them off after 2hrs) Has anyone had this problem, or know where the button is that should shut the lights off?
Thanks, Jeff
jraben is offline   Reply With Quote
Old 10-09-2006, 02:54 PM   #2
deliriousga's Avatar
Check the light between the visors. It flips to three positions, on, off and auto-on when the door is opened. It should be angled (both "on" positions are when the light is at an angle and the off position is when the light is flat). Flip it to the other angle then close the doors (from outside) and lock the doors to see if the lights go out.
Hope it helps.
1966 Wife White/Brown Top
Old 10-09-2006, 08:33 PM   #3
Thanks but I tired that, I won't even lock.
Old 10-09-2006, 09:46 PM   #4
When you set the alarm do you get a beep like something is open?
Old 10-10-2006, 11:22 AM   #5
Yes i do.........
Old 10-10-2006, 11:48 AM   #6
Interior Light Problem--->ignition switch
Friend:
Any trouble getting the key out?
Is your radio also staying on?
Maybe ignition switch is going.
db
Cecil Suzuki is offline   Reply With Quote
Old 10-10-2006, 11:59 AM   #7
Originally Posted by jraben
Yes i do.........
Then it sounds like one of your door switches is not working properly. First make sure your middle console is closed completely (clicks) along with gas door, both trunks and doors then use the remote to lock the doors and see if you get the beep. If you do, open one of your doors and push the button down that normally turns the lights off. Twist it some to see if it can make contact and push it in to see if the lights go out. If not, try the other side.
If that doesn't work, you could pull the alarm codes with the durametric tool if you have it or know someone who does and see if there's something up with the alarm/locking system. I don't think there are any relays for the interior lights so I'm not sure where to go from there. Hopefully Tool Pants has run into something in the past that can help you out.
Old 10-10-2006, 04:22 PM   #8
Sounds like your car thinks the door is opened when it is actually closed.
The usual suspect is the door latch that has an open/close switch on it.
Old 07-01-2010, 11:59 PM   #9
interior lights staying on after shut-down
Hope it helps.
This works! Cheers to YOU! I love this 986 Forum~ Also... anyone that has check engine lights on, get the codes and search through this site... its saved me a TON of "blind" repairs!!!
LZ
lorizinn is offline   Reply With Quote
