Old 09-10-2019, 07:32 PM   #1
Rear control arm install: how the hell...
...Do I properly torque the nut on the joint? The nut is immediately below where the axle inserts into the wheel hub. I can’t get the Torx socket on there to keep the joint from spinning. What am I missing?
imhighlander is offline   Reply With Quote
Old 09-10-2019, 07:58 PM   #2
Answer... jack up the car below the control arm to load the joint. Problem solved.
Old 09-11-2019, 04:29 AM   #3
1998 Boxster Silver/Red
I can't see anything. Can you zoom in on that a little more.
1998 Porsche Boxster
Old 09-11-2019, 04:40 AM   #4
Tailwind's Avatar
+1 what imhighlander said. I think I tried putting a short Torx bit on the shaft and counter holding it with a small crescent wrench. Then estimate the torque using an open end wrench. Otherwise, put a wood block on the jack and load the ball joint then wrench it. Be careful not to hit the backing plate. Any tweak of that will result in the rotor scraping it. Ask me how I know.
'99 986 Base
2010 Golf TDI
'74 914 2.0
'56 356A
Tailwind is offline   Reply With Quote
Old 09-11-2019, 05:28 AM   #5
steved0x's Avatar
Often times you can torque it just by pushing it from the bottom with your hard and tightening the nut. Once it draws the tapered shaft in there, it will stop turning. IF that doesn't work, otherwise I use my hockey puck on the jack and lift the control arm from under the ball joint to load it, and then crank down with a box wrench
Old 09-11-2019, 06:32 AM   #6
Who's askin'?
maytag's Avatar
That's what she said.
(..... Michael Scott.....)
Old 09-12-2019, 05:40 PM   #7
I might need them also if they are bad do they make a clunking noise/ or feel behind the seats,.??
Old 09-12-2019, 08:01 PM   #8
I torqued both of mine to the good-n-tight standard. So far so good!
Old 09-13-2019, 03:01 AM   #9
piper6909's Avatar
Most likely you need these:
https://www.pelicanparts.com/More_Info/98633104307M80.htm?pn=986-331-043-07-M80&bt=Y&fs=0&SVSVSI=
Old 09-13-2019, 03:56 AM   #10
Ha Ha!
Old 09-13-2019, 05:25 PM   #11
Thanks Piper,..Ill check that out
