Old 08-06-2019, 12:02 PM   #1
lcsdoug's Avatar
Broken push rod cup
Plastic push rod cup on driver side of top broke off. Has anyone used the Pelican metal cup replacements? Sure looks like a better idea. And cheaper than a whole new arm. Now if only I could get the top up until the parts arrive.
2007 Speed Yellow Boxster S
"Never let the fact that you don't know how to do something keep you from doing it." - Me
lcsdoug is offline   Reply With Quote
Old 08-06-2019, 12:17 PM   #2
It is NOT a better idea. If somethings jams you would much rather have a plastic cut break than have a much more expensive part of the mechanism bend or break.
If the cup broke there's a reason. Check the mechanism and fix the underlying cause.
1941 Dodge Luxury Liner Coupe
Old 08-06-2019, 01:05 PM   #3
lcsdoug's Avatar
Good point. I think I'll take it in for an estimate. Over my pay grade.
Old 08-06-2019, 01:47 PM   #4
What year? My '01 had that happen, they will wear out, so you may be lucky. If you replace yourself make sure the arm is same length as the one you are replacing. Then watch that the top is going up/down evenly on both sides.
Sent from my SM-N960U using Tapatalk
mmassey0125 is offline   Reply With Quote
Old 08-06-2019, 02:20 PM   #5
lcsdoug's Avatar
I think there is something else wrong. As the other gentleman said I think it's a symptom of another problem. It goes halfway up then sort of grinds to a halt. When I put it down I hear some clunking noise in the rear. I made an appointment with a good indy guy for an estimate tomorrow. I'll try a lot of things but convertible tops kind of scare me. I'm leery of the damage I can do. $$$$$$
Old 08-06-2019, 03:16 PM   #6
2003 Base 5-speed
grc0456's Avatar
Just say no to metal, in this case.
Old 08-07-2019, 10:39 AM   #7
Multi-Boxer Driver
Deserion's Avatar
It’s possible the plastic gear in one (or both) of the roof transmissions has cracked. That can cause jamming. Gear replacements are available as well.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 09-21-2019, 06:32 AM   #8
lcsdoug's Avatar
Just a follow up. I took it to my indie place and he replaced both pushrod arms (nylon cup) removed and re aligned the top. No damage to the transmission. Added bonus, I don't have to put my arm out the window to guide the top into the channel.
