Old 05-15-2019, 07:16 PM   #1
Intermittent radio
I got my Becker CDR 210 working (found the code) on a recently purchased 1999 boxster. But now the problem is when the key is turned on in the first position ( not turning the starter) the radio / CD works fine but once I start the motor the radio turns on and off constantly. I’m not sure if it’s the radio or the power supply.
wrs986 is offline   Reply With Quote
Old 05-15-2019, 07:19 PM   #2
Any other strange behavior from other accessories ?
Many here like me will suggest a faulty ignition switch.
pomerlo is offline   Reply With Quote
Old 05-15-2019, 09:13 PM   #3
x2
(but message too short)
"Cool Prius!"
- Nobody
Old 05-16-2019, 03:47 AM   #4
Everything else seems to work fine. It’s the base model so not a lot of accessories. Windows, top,HVAC, Cruise control , wipers, and lights all works as they should. I would expect other issues if it is a ignition switch. How do you check for something like this?
Old 05-16-2019, 04:25 AM   #5
X3
Search on here for ignition switch problems. Extremely common for the switch to go bad. I think a new one is $25-35
Woody
Old 05-16-2019, 06:22 AM   #6
Tailwind's Avatar
X4
Turn the key slightly to the left and see if the radio stays on.
'99 986 Base
2010 Golf TDI
'74 914 2.0
'56 356A
Tailwind is offline   Reply With Quote
Old 05-16-2019, 07:21 AM   #7
1998 Boxster Silver/Red
Why? Why would you expect other issues? Everything I've read about ignition switch anomalies suggests it could be just one issue, or many.
I can imagine how annoying it is, and I'm waiting for the day for one of those anomalies to surface. The ignition switch will be my first go to. Good luck.
1998 Porsche Boxster
Old 05-16-2019, 02:00 PM   #8
I just drove the car today and the radio faded it in and out for the first 10 minutes of driving and then it started working fine not sure what the problem was
Old 05-16-2019, 03:08 PM   #9
Sounds like a wonky HU.
Tags
intermittent radio
