Old 05-02-2019, 08:08 AM   #1
Coil pack reccomendations?
Hello all, last week I replaced the pads and rotors as well as changed the oil. The oil filter wasnt tight or the oring failed so I was leaking oil. I got some degreaser and a hose and cleaned underneath the engine. As I drive off the ramps the car is running like crap. Engine light came on and 2 cylinders are misfiring. I cleared the codes and I parked in the garage for 2 days. Car starts and runs fine now with no codes. I'm looking at new coil packs and curious if there is a difference in brands for a non tracked daily driver? Its a 2003 base with 45,000 miles thank you
One day my wife will learn I do not work hard and I will have to start waking up with the kids and dog.
jimmythemufflers is offline   Reply With Quote
Old 05-02-2019, 09:59 AM   #2
1998 Boxster Silver/Red
Behr. Once is done.
Buy cheap. Buy twice.
1998 Porsche Boxster
Old 05-02-2019, 10:06 AM   #3
Will there be cake?
tonythetiger's Avatar
Behr. Once is done.
I think you mean Beru, yes those are nice :+)
you should find quality coil packs for around 30 bucks each if you buy 6
IMHO, if they aren't cracked or faulting...they are working, but I understand. Its comforting to replace all of them at once. To that point, its a good time to replace the spark plug tubes and sparkys at the same time.
Old 05-02-2019, 11:32 AM   #4
Need For Speed
KRAM36's Avatar
Your 2003 model will not have spark plug tubes, so don't worry about buying those.
2003 Boxster S
Old 05-02-2019, 12:12 PM   #5
Thank you for the correction. Behr is paint... and that isn't happening this summer.
I replaced all of mine at once... even though all of them seemed to be operating properly. Bought the car with 114K, and had no benchmark, so I set my own. Also... shared with other members the ones I removed. Gratis.
Cheers!
Old 05-03-2019, 04:51 AM   #6
mikesz's Avatar
My 99 was throwing CEL on the left bank so I replaced them with Beru like $35 each. the old ones looked fine obviously had issues. While I was at it I did the right bank of cylinders which were NOT throwing CEL. WOW! They were cracked I couldn,t believe they were still working.
99 Porsche Boxster
Old 05-09-2019, 05:18 PM   #7
Pathological Tinkerer
When I replaced mine last fall I used the updated 997 part. The potted area on the 997 part is a little deeper so you have to use a longer screw but the coils came with new ones. I used the Beru units.
P_Carfahrer is offline   Reply With Quote
Old 05-09-2019, 05:59 PM   #8
Don't forget y'all can check coil packs with an ohm meter. 115k miles on my originals...no cracks and ohm tests are within specs (forgot the numbers but found it before in search).
Old 05-10-2019, 12:29 PM   #9
Thanks for all the feedback. I went with these
Part# 997-602-107-02-M47 from pelican. I like saving money but it doesnt look like I should try with this. Thanks y'all
