Old 02-13-2020, 06:58 AM   #21
98 Arctic silver 986
tommy583's Avatar
That basically looks like the EVO intake Fabspeed used to sell, only now more expensive. It still doesn't seal the engine bay from the filter section. That rubber on the top edge is below where the top cover will be, it will never seal like that. Why can't they just make it a sealed box with some kind of air tight door to service the filter? Why does it have to cost so much? I mean really $500 for a piece of metal, a foot of plastic tube and a cone filter.
Old 02-13-2020, 09:57 AM   #22
2001 Boxster S
SpIcEz's Avatar
I agree the price is quite outrageous.
As for sealing, I dont think its a problem. If you find it doesnt seat well, you could add foam or something else under the rubber seal to make it tighter.
But, honestly, to me it just demonstrates all the naysayers saying you NEED a stock airbox to make power are saying nonsense.
There is nothing magical about their design. And the M96 works just like 100% of all engines out there. Less restriction = more power.
They show considerable gains on that dyno. Now, on the other hand, I'm sure you wont get that in all conditions. Especially on a hot day when things are heat soaked.
I can build one like that, only thing is to find a MAF flange for 986/996 MAF sensor to weld on a suitable aluminium pipe.
SpIcEz is offline   Reply With Quote
Old 02-13-2020, 02:16 PM   #23
EZ-PZ....
https://shop.advanceautoparts.com/p/spectre-mass-air-flow-sensor-adapter-87051/11430025-p?c3ch=PLA&c3nid=11430025-P&adtype=pla_with_promotion&product_channel=online&store_code=&gclid=CjwKCAiAhJTyBRAvEiwAln2qB3I459So1fmiJ8C87j9N 4NnnrZZOKqzM7L05jwpSLgje1VT4aKsCthoCx4MQAvD_BwE&gclsrc=aw.ds
You can get MAF housings cheap. Bolt on plastic configuration, or the aluminum like above.
Tremonte986 is offline   Reply With Quote
Old 02-13-2020, 07:33 PM   #24
Topless's Avatar
It's easy to overthink this stuff and get sucked into the marketing hype vortex.
Back in 2005 there was a lot of independent dyno testing going on to compare different intake airbox designs. The airbox should do 2 things well: Let plenty of cold air in while keeping the hot air and bad stuff out. As I recall these were the basic results after a LOT of testing:
Stock 986 airbox worked fine on a 2.5L
987 airbox added 1-2hp primarily on 3.2L models
Cone style EVO filter inside the engine compartment lost 2-3hp due to higher intake temps, and rapid oiling of the MAF sensor caused the engine to run poorly. It was discontinued.
Boxster Spec Race cars all run stock 986 box and (I think) stock paper filters.
Old 02-13-2020, 07:55 PM   #25
2001 Boxster S
SpIcEz's Avatar
Did no one test a well sealed paper cone filter?
Just seems like they abandoned half way through.
Boxster aren't the only IC engines on the planet, principles of physics and engineering arent different in the M96 universe, unless I'm mistaken.
There is a reason that ITBs are the best nor NA engines, if you manage the air fuel right.
The most direct route is the best.
It just seems like everyone who abandoned just didn't build a well sealed unit to keep hot air out.
Old 02-13-2020, 10:11 PM   #26
Topless's Avatar
No one built a well sealed cone style paper filter so no, none tested. What is your attraction to the cone style specifically? Do you think it flows significantly more air than a pleated filter in an airbox designed and tested extensively at the Porsche R&D facility? Have you actually flow tested this yourself or do you rely completely on marketing claims? I suspect that the Porsche R&D testing is 100x more sophisticated than any aftermarket air filter company. What does Porsche use for their winning factory team GT3 Cup cars at 24hr Le Mans and 24hr Daytona? Check it out yourself.
Show me some hard independent data and we can have a conversation about which filter types measurably improve intake flow rates. Bisimoto did about the most extensive independent flow testing and he did not find significant improvement on the Boxster. Test results were within the margin for error (1-2hp) on his dyno for a given day.
There are applications for a cone style air filter and Bisi uses 2 on his completely custom 850hp Twin Turbo 911. They were an obvious choice because the turbos hang off the back of the car and need to be cleaned often being fully exposed to road grime. He has now gone fully electric with a 650hp Porsche 935. Fun guy and he lives about 20 minutes from my house. We see him often at events.
https://www.youtube.com/watch?v=-4HVBx1TmGE
Old 02-13-2020, 11:31 PM   #27
Who's askin'?
maytag's Avatar
You're almost right. Or shall I say, half right.
I've been contending since I joined the Porsche world that there is no magic. These motors will respond to improvements, just like any other.
But here's the caveat: make sure you're really improving.
Why are ITB's the choice for many extreme- performance applications? Not because the most direct route is the best, as you stated, but rather because they are best at delivering large volumes of air at high velocity in a meter-able fashion. A difference with a distinction.
ITB's are not always better. They become a favored choice when traditional (cheaper) methods can't provide enough air for a motor's specific volume at rpm. But up until that point, they offer little (or no) benefit.
In other words: can your 986 engine in standard trim use more air than the OEM intake can provide? Tests show the answer is clearly "NO". And there's where the Porsche "magic" (which isn't magic at all) happens: that 986 intake was designed well enough that you need to modify other things before you'll see a need for an improved intake. This isn't your LS Camaro, trying to breathe through a tiny slot in a plastic can, with a spring loaded flap blocking it.
Start with the exhaust. Get it to breathe better there, then maybe a hi flow air filter can help. Then increase the size of the TB, and you will want to increase the size of the intake feeding it. But just throwing on an intake that can feed more air than the motor can use isn't going to help it.
And then there's the risk of introducing hot air while you're at it.
Old 02-14-2020, 03:33 AM   #28
1998 Boxster Silver/Red
Hi May!
All that makes sense.
What about gutting the 986 aitbox internals... removing any internal mufflers... bends... twists... and turns? In other words... mitigating the internal turbulance caused by the twists and turns? Would have to remove the airbox... cut it open... take a Dremel or something to it... seal it back up... reinstall.
I'm curious.
I know Porsche engineers ran the numbers... but I'd like your opinion.
1998 Porsche Boxster
Old 02-14-2020, 03:53 AM   #29
2001 Boxster S
SpIcEz's Avatar
I 100% agree, that an intake by itself, wont give you much.
Exhaust, plenum, throttle body, etc.. are necessary to actually benefit.
And we are agreed as well that heat management is key. Its obvious by the placement and closed nature of our engine bay that, its not enough to just throw in a filter with more direct intake route.
There just seems to be this contention that there is no way to make more power than stock box, which I just cant believe from experience.
Old 02-14-2020, 05:09 AM   #30
Who's askin'?
maytag's Avatar
Nah, you're right. I think where things get lost is the real cost:benefit. Take my 5.7 hemi: Its pretty easy to add a CAI and swap a tune and find 20hp. Hell you can find 12-15 with the CAI-alone.
But with the m96 in the boxster, you need to spend large dollars on multiple modifications to see the same sorts of increases.
On mine, I've done headers, de-cat, by-pass valves, 78mm tb, 987 airbox and intake with the EVO filter and riser , lwfw, udp, and a tune. Yeah.... add that up in your head. Haha. I bet I've found maybe 5HP on top. (Though I've fattened the curve a bunch). I haven't had it on a dyno, but I've got a lot of years on the "butt-dyno".
Why'd I do it then?
Can't help myself. I modify, therefore I am. It's what I do. It's the bigger part of the fun of an enthusiast-car, to me. I've got some mods I don't like much, and next year I'll change them.
I think ya just have to be realistic about what you may find, and to many / most people the cost: benefit to modifying the M96 in the boxster just isn't there.
Fun fact: i'd probably get more performance increase by going on a diet and dropping 30lbs. Hahaha
Old 02-14-2020, 05:11 AM   #31
There's 60HP right there. :dance:
Old 02-14-2020, 05:48 AM   #32
2001 Boxster S
SpIcEz's Avatar
Indeed, Im in that same boat
Installed Sparco Chrono Road seats, as my stock seats where torn appart and wanted something to hold me better.
However, to fit my fat a$$ I probably ended up with heavier seats than stock, or at the least no weight loss...
They look good though
As for the rest, you are right, people assume because you get massive intake gains on some cars, you will get it on others.
I agree with "I modify, therefore I am!"
It takes every inch of my soul not to tinker with my winter car, but so far, so good.
Old 02-14-2020, 06:24 AM   #33
piper6909's Avatar
Me too!! We should get a group of members and do a "Biggest Loser: 986 Edition"!
Old 02-14-2020, 06:54 AM   #34
Topless's Avatar
The whole point of modding a car is to measurably increase performance and that is tougher on a Porsche because those crazy Germans already did a pretty good job. Just bolting on sexy parts won't get it done. We need independent measurement and verification to separate legit gains from the BS, and get beyond the marketing hype which is pretty rampant.
All of this 986 stuff was tested extensively about 20 years ago and the results were interesting and often disappointing. Aftermarket products failed to meet their claimed HP improvements across the board. Fabspeed makes sexy products and their exhaust is arguably the best looking and best sounding of all aftermarket exhausts. They claimed a 22hp bolt-on gain but independent testing showed the stock exhaust actually made more power with a fatter torque curve. They claimed a 15hp gain with the EVO intake but independent testing showed -3hp and higher intake temps.
Underdrive pulley- Verified 3-5hp gain to the wheels across the RPM range by reducing parasitic drag.
Weight loss- Verified improvements in acceleration, braking, and cornering.
Plenum- Combined with TB, exhaust, and custom software tuning- 10-15hp depending on model with more improvement on the 3.2L.
Airbox- 987 box performed the best gaining 1-2hp on 3.2L
If we are serious about improving performance we need to do the math, and before and after testing to confirm that gains are real and not just marketing BS.
In an earlier life, we used to hot rod Ford, Chevy, and Honda motors to race at the drag strip and off road. Detroit mfg tolerances were pretty loose then with a lot of internal friction and you could make 30hp verified simply with a balance and blueprint, getting everything up to the engineering specs. Add a real intake manifold, Holley carb and custom exhaust instead of those stamped things from Detroit and there might be another 30hp verified as we allowed all that displacement to measurably breathe better. Porsche doesn't miss much, tolerances are a lot tighter, and we have to get more creative to squeeze more power from these well-tuned little mills.
Tuning is fun as long as you independently measure and verify gains along the way. This requires regular visits to a fairly precise dyno. Trusting aftermarket marketing hype is a fools errand and leads to disappointment.
These guys did a pretty good study on Boxster tuning and they did significant before and after testing along the way. A few interesting findings: They did not find improvements with an underdrive pulley as many other's have seen and verified. Also the stage 1 ECU remap caused the power to be down 10 hp vs the stock ECU tune on their modded car with a rich AFR. A custom dyno tune would probably deliver more juice if they got the AFR really dialed in.
https://www.youtube.com/watch?v=kja5LSsUT_g
Old 02-14-2020, 11:24 AM   #35
I'll put this here instead of a new thread as it is somewhat applicable. Care to comment on my plans on a 2.5 base? I'm thinking maybe +10 whp?
- Underdrive pully - check.
- Lightened flywheel/clutch? - In a nutshell, Raby said the 2.5 could handle this the best. Is there such a thing as a lightened dual mass flywheel?
- Weight loss- -367 lbs. (2,455) so far. Goal around 2,350, including weight added back on (structural stiffening and body work/aero).
- TB, software?, exhaust (headers, 2 cats, no mufflers (for weight loss) - still need the headers. Will I need 2.5 specific headers? Would Pedro's system work adequately with the semi-custom software? Alternatives; rolling dyno plus? I'm looking for a broad range torque improvement, not 6700 rpm hp. This is more of an auto-x/street car than track - built for fun and don't care about being class competitive.
- Manual steering.
- Re-working of body/drag but I'll leave this alone for now but it will reduce the hp required to go x mph.
Hasbro is offline   Reply With Quote
Old 02-14-2020, 04:04 PM   #36
Topless's Avatar
- Manual steering.
Weight loss and UD pulley are a slam dunk. Intake/exhaust/DME software are a moving target and best done together with a custom dyno tune. I don't see much benefit in any off-the-shelf flash unless it gets further tuned to your specific car and mods. Everything needs to work well together and then you can find some hidden HP.
A lightweight flywheel was on my brother's 2.5L car while mine retained the dual mass. It definitely spooled up faster and was a little quirkier to drive around town. We never dyno'd B/A this change and we noticed no difference in lap times. He was usually a bit quicker on tight tracks and I was quicker on more open tracks, always within a few tenths.
The only benefit to me for manual steering is a little weight loss. The PS pump is very reliable once the UD pulley is installed.
Good luck and test/verify as you go!
Old 02-14-2020, 06:50 PM   #37
For manual steering, is anything needed to be done to the rack, or just remove the pump and lines?
'97 - Silver (rebuilt/stripping)
'99 - Black (rebuilt/sold)
'01 S - Rainforest Green (daily)
'03 S - Orient Red (sold)
Fiddlebog is offline   Reply With Quote
