Old 03-30-2019, 12:27 PM   #4
In the Bentley manual on page 94-6 is a photo of my dilemma . It says slide switch faceplate approx. 5mm(1/4) out of vent, then turn switch body slightly counterclockwise to remove. My switch faceplate is frozen in place, no sliding . If you can't slide you can't rotate the switch as the faceplate sort of locks it in place. Its almost if it was glued in at some point. Gluing is not needed as the big nut holds it in place. Anyone ?
MrBen is offline   Reply With Quote
