Old 03-12-2019, 10:05 AM   #1
Switched +12V in rear trunk of 2004 Porsche Boxster
Hi All,
I did some search on the forum but could not come up with a good location.
Am looking for Switched 12V (switched on with the ignition key) locations to tap into in the rear trunk of my 2004 Boxster Base. Something I can use for powering the main contractor assembly for my conversion. Reasonable current capacity will be ok.
I don't have the service manual so if you are pointing me to a pin on a connector, I would appreciate the help in finding that exact connector. A pic would be ideal...
Appreciate the help in advance!
Current Project: 2004 BoxsterEV - http://amsoneji.wix.com/boxsterev
PorscheFan5 is offline   Reply With Quote
Old 03-12-2019, 10:51 AM   #2
Switched 12V in rear trunk
I had found the following by 'jsceash'...
"X59 Plug pin location 4 White plug next to ECU (left of ECU) Red wire blue stripe fairly heavy wire come from ignition relay and turns off about 30 seconds after ignition is off."
However don't know which is X59 connector and how to identify pin 4. Hence my request to post a pic with some brief info.
Thanks in advance!
Old 03-13-2019, 05:45 PM   #3
Answered the question for myself...
Have posted the info so it is useful for someone else in the future...
http://986forum.com/forums/performance-technical-chat/74753-switched-12v-rear-trunk-2004-porsche-boxster.html#post590869
Old 01-29-2020, 09:57 AM   #4
Who's askin'?
maytag's Avatar
Sent from my bucket in the garage
Old 01-29-2020, 02:34 PM   #5
Who's askin'?
maytag's Avatar
