Old 02-27-2019, 04:19 PM   #1
Emission numbers and the IMSB
If you have a failing IMS, would it reflect in your emission numbers as in running to rich or running to lean if that's even possible with Cat's and ECU's on a boxster ?? Thanks.
flmont is online now   Reply With Quote
Old 02-28-2019, 08:51 AM   #2
No...…………..
Old 02-28-2019, 06:58 PM   #3
thank you,.I thought it may make the valve train act up
Old 03-01-2019, 05:27 AM   #4
By the time the IMS significantly effects cam timing, the engine is seconds from death.
