Old 02-26-2019, 07:32 PM   #1
jmitro's Avatar
bad grinding in corners
99 base 2.5L, 5spd manual with 120k miles.
in tight corners with heavy throttle I hear a bad grinding noise from the rear end, like dragging steel pipe over a concrete floor. It does not happen with light throttle or in long sweepers.
I don't see anything obviously binding or grinding. All suspension pieces are brand new. I'm thinking the most likely culprit is a bad CV joint (boots are clean, no grease leaking) or maybe a bad wheel bearing (they don't seem loose when I rock the wheels with the suspension unloaded).
any other thoughts?
07 Porsche Cayman S speed yellow
87 Porsche 924S Carrera GT project/ 951 engine transplant
2015 BMW X5
jmitro is offline   Reply With Quote
Old 02-27-2019, 03:39 AM   #2
Who's askin'?
maytag's Avatar
Wheel bearing would be my first inclination as well.
Old 02-27-2019, 04:05 AM   #3
+ 1 on wheel bearing
Yes, with 120k miles it could well be a wheel bearing, better to replace both sides.
They are not too expensive (Pelican) and you will have a lot of fun replacing them..
Old 02-27-2019, 06:05 AM   #4
jmitro's Avatar
Lol thanks. I have all the tools including a 12 ton press. 😁
Old 02-27-2019, 06:58 AM   #5
The Radium King's Avatar
there is a test for wheel bearings. while you have the car on stands, also check your diff.
Old 02-27-2019, 08:16 AM   #6
jmitro's Avatar
How does one test wheel bearings? I thought it was to grab the wheel at 3 and 9 with tire off the ground and see if it feels loose
Old 02-27-2019, 08:37 AM   #7
Smile Grinding sound
When you have the Car on stands, a few simple wheel spins and you can listen and feel
for unusual grinding sound. Done this on a few occasions on my other cars. Hope this helps.
t2-bxtrs is offline   Reply With Quote
Old 02-27-2019, 08:57 AM   #8
ah - i re-read your initial post - you did test them and no movement. personally, i think that since the noise is proportional to the amount of power applied, that it happens in tight turns yet the the rear wheels don't turn, that you may have to look to your diff - you get the sound when one wheel is slipping perhaps.
Old 02-27-2019, 05:58 PM   #9
98 Arctic silver 986
tommy583's Avatar
It could also be your center motor mount. Mine sounded similar only on hard throttle in tight corners. Have someone follow your car and see if the tail pipes move a lot when you get on the throttle hard. Or if the shifter moves a lot when you get on it.
Old 02-27-2019, 08:59 PM   #10
My motor mount also sounded like grinding when turning. If it hasn't been replaced by 120k...I'd do that first.
Old 02-28-2019, 05:04 AM   #11
jmitro's Avatar
Definitely. I have a laundry list of repairs to make and motor/transmission mounts are on it. Hopefully the problem is not the diff.
Thanks all for the replies!
Old 03-29-2020, 06:57 AM   #12
jmitro's Avatar
thought I would update this thread with a note that replacing the motor/transmission mounts cured the grinding noise, so it was definitely not the differential
2015 BMW X5
Old 03-29-2020, 09:31 AM   #13
I have a grinding noise caused by bad transmission and motor mounts. Occurs when under heavy acceleration in first and second gear.
Have the parts, just need time to replace them.
1941 Dodge Luxury Liner Coupe
Old 03-29-2020, 02:43 PM   #14
tommy583's Avatar
Glad you got it sorted out
