Old 11-01-2018, 12:34 PM   #1
Ciao's Avatar
Smell of Burned Rubber
Driving my P car yesterday evening I noticed an unusual smell of burned rubber coming from the right rear wheel (course that's where the engine is located). But, I had no engine lights, temp was normal, I was not burning rubber, the evening was cool (below 50 degrees). Engine seemed to be running fine--
Any tips/advice what caused this?
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 11-01-2018, 12:55 PM   #2
still plays with cars...
BoxsterSteve's Avatar
Is yours an S?
They are notorious for eating CV boots. Mine kinda stank as you describe when they went bad.
Crawl under and take a look.
Six speed 2000 Boxster S
Old 11-01-2018, 01:41 PM   #3
+1 for CV boots. Do them all and move on!
Old 11-01-2018, 01:41 PM   #4
Ciao's Avatar
Yes it is an S. I had the boots replaced this summer; I'll check though
Old 11-01-2018, 03:01 PM   #5
They are new...
Mine did that stinky stink after the boots were replaced too... took months for it to go away.
Old 11-01-2018, 05:26 PM   #6
Ciao's Avatar
Originally Posted by BoxsterSteve View Post
They are new...
This is the first time I've smelled it since May when I got the boots replace. But I did go on vacation and didn't drive it till a month ago; once!
Old 11-02-2018, 07:37 PM   #7
So new boots! That's new info! Perhaps you were smelling left over grease that was slung out onto your exhaust that had'd burned off yet.
It's still worth getting eyeballs on the boots. It's possible that a clamp has slipped or become loose.
Old 11-03-2018, 02:52 PM   #8
Ciao's Avatar
"Left over grease that was slung out..." Not sure what that means. At any rate, I went on a 2 hour drive in heavy traffic and the smells was still there. I am beginning to believe it is with the CV boots and am inspecting them as I go along; no tears in new boots. I used the heater for the first time in 2 years thinking maybe that is a variable, but not sure. The inputs related to new CVs has narrowed my search.
Old 11-04-2018, 04:00 AM   #9
That rubber burning smell was, for me, the belt going. Pullies had seized or where not spinning well, and the belt eventually broke.
CDNIcecube is offline   Reply With Quote
Old 11-04-2018, 06:57 AM   #10
Ciao's Avatar
That was my first thought, but I replaced the belt in June (this summer) @39K miles
Old 11-04-2018, 12:00 PM   #11
"50 Years of 550 Spyder"
10/10ths's Avatar
Check the....
.....idler pulleys on the serpentine belt.
Mine was bad after only 25,000 miles on my 2004 S.
I have seen multiple fires caused by a seized idler pulley setting the serpentine belt on fire on these machines.
Old 11-04-2018, 02:11 PM   #12
Ciao's Avatar
How do I check the idler pulleys?
Old 11-04-2018, 03:18 PM   #13
10/10ths's Avatar
Simple...
....remove the serpentine belt and then grab the pulleys and try to wiggle them and then spin them by hand. They should not wobble and should spin freely with no noise. If they wobble, or go crunch crunch, replace them.
Old 11-04-2018, 03:25 PM   #14
Ciao's Avatar
Thanks! I will check that; if they are fine what is the next potential item to check?
Old 11-04-2018, 06:16 PM   #15
What I was referring to is that when boots crack, your axles spinning will cause the grease in the boot to end up all over the underside of your car.
Old 11-05-2018, 11:05 AM   #16
Ciao's Avatar
they spin freely with no noise
