Old 10-29-2018, 07:45 AM   #1
Stiglitz's Avatar
Water Pump Frustrations
Starting to get a small leak on water pump, thought it was hoses, replaced, still leaking, looked further, its the water pump. Ordered all the parts I need to swap out (serpentine I did in April, and hoses a month ago, so just water pump, tstat and housing to take care of, and I end up down for the count with a pinched nerve in my neck, so I can't do it.
Having a HELL of a time finding someone that will install for me for a reasonable price. I actually had someone quote me $1,100 for it!! That is insane!
Even on my worst day, 4 hours max messing around with it. Still looking around. If anyone knows anyone in Orlando area that will do just labor, please send me their number. I'd rather not drive around w/pending failure, and waiting on my neck to heal will probably be about another month.
Thx
Stiglitz is offline   Reply With Quote
Old 10-29-2018, 10:15 AM   #2
i had the same issue, i was getting quotes up to $1,800 for Water Pump, Thermostat, and Front Motor mount, labor only!!! it was insane!
Kept looking and found a reputable shop to do the work for $600. Still not cheap but seeing as though most indy quality shops are charging a minimum of $150 hr these days it's hard to find reasonable prices for work. Need to locate a place that charges actual labor and not book rates then use them regularly so you build a relationship.
dav9515 is offline   Reply With Quote
Old 10-29-2018, 06:16 PM   #3
Thx
Crazy! $350 worth of OEM parts and coolant...a couple of hours to complete.
Old 10-29-2018, 06:41 PM   #4
Even $600 for labor is high! That job should take about 2 hours all in, or at least that's what it took me
Nedlands is offline   Reply With Quote
Old 10-29-2018, 07:33 PM   #5
Multi-Boxer Driver
Deserion's Avatar
Funny that I’m doing the water pump on a 987 right now. If you were closer I’d offer.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 10-29-2018, 10:45 PM   #6
It takes longer to get the car panels off then bleed the coolant system afterward than it does to swap out those parts! 1000.00 is nuts! Or, maybe I should start doing repair work on the side!? I think all in, totally taking my time was maybe 3 hours, and that included various extra cleaning, etc.
Old 10-30-2018, 02:30 AM   #7
I see you are in Winter Park there is a shop in Orlando on Semoran Blvd. that used to be known as Zotz . It was bought out by Donny years ago from original owner Ron Zitsa . I used them exclusively when I lived in Orlando . He is/was very knowledgeable and reasonably priced back then but I have been gone from Orlando almost 9 years now . The shop was behind the Original Mattress Factory .
Old 10-30-2018, 04:35 AM   #8
flouese's Avatar
I changed my water pump this past weekend due to a slow leak (drip). Less than two hours. Turned out it was the gasket that was bad. Now I have 2 water pumps laying around. One with the metal impellers and one with the plastic ones and brand new gasket to go with it. If anyone needs one, let me know.
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 10-30-2018, 04:57 AM   #9
mikesz's Avatar
WOW! I am in the wrong business! I have changed waterpump on my 99 twice. First time I did thermostat, fresh coolant, new motor mount. Second time just water pump.
99 Porsche Boxster
Old 10-30-2018, 12:49 PM   #10
Stiglitz's Avatar
Thanks all for input!
Actually one of the local indie/dealers in town is charging me 4 hours, so I'm just gonna bite the bullet and get it taken care of.
Can't let it sit in garage while my neck gets better, just not that patient!
I also figured out my window issue, blown fuse
Old 11-01-2018, 07:08 AM   #11
Stiglitz's Avatar
Got it taken care of. Sean at Nort Northam Collection in Orlando did an AWESOME job. Quick, correct, and Fair!
Highly recommended!
