Old 10-23-2018, 07:34 PM   #1
Durametric question
I seem to have lost my instructions for hooking durametric (dm) to car.
I'm thinking I connect DM to computer.
Plug cord to car
Turn key so dash lights come on (don't start)
Also, can DM be used to help bleed brakes on a 986?
Thanks.
DWBOX2000 is offline   Reply With Quote
Old 10-23-2018, 07:35 PM   #2
Seems like a handy tool when looking at new cars.
Old 10-23-2018, 10:29 PM   #3
There Is No Substitute.
rick3000's Avatar
You can use the Durametric with the car on or off, and you can use it cycle the ABS pump, I don't believe you can bleed individual calipers on the 986 with it. If you call Durametric I have found them to always be helpful
If you are using it when car shopping, be aware that the enthusiast version locks after it recognized 3 VIN's.
Old 10-24-2018, 04:01 AM   #4
Hi Rick,
Thanks for responding. I'll give it a try.
Also, The dm site says unlimited for used car data for enthusiasts.
Old 10-24-2018, 04:15 AM   #5
Artist, 986S tinkerer
NewArt's Avatar
Yes, you can read basic data and it won’t register a new vin. I ‘m not sure just how much you can read though. Can I go into actual values to see the cam deviations for instance?
Old 10-24-2018, 09:42 AM   #6
The Radium King's Avatar
it'll read deviations, reset airbag stuff, and cycle the abs pump which is what you need for brake bleeding when you have traction control.
Old 10-24-2018, 10:21 AM   #7
NewArt's Avatar
I should have appended “without registering a new vin” to my question, as in “Can I go into actual values to see the cam deviations for instance, without registering a new vin”?
Old 10-24-2018, 10:36 AM   #8
i think that depends on the version - enthusiast or professional.
Old 10-25-2018, 04:57 AM   #9
I used mine to view actual values and activations and it hasn’t locked into any vin as of yet
986bsdriver is offline   Reply With Quote
Old 10-25-2018, 12:13 PM   #10
I read that you can read anything, but making any changes or clearing codes registers the VIN. Not Certain that is correct though.
2000 Black 996 Aero, 2001 Forest Green Boxster S, 94 Midnight Blue 968 Cab, 1980 Pongee Beige 911SC Weissach Edition, 2004 BMW R1200CLC
ymkmkrz is offline   Reply With Quote
Old 10-25-2018, 04:43 PM   #11
I haven’t made any changes yet, but have used it to clear codes. Still have 3 open vins
Old 10-25-2018, 06:20 PM   #12
NewArt's Avatar
Not quite sure how it works. On my previous car I used the Durametric for 2 years and it never showed a registered vin. When I started using it on my present car, lo and behold the first car vin showed up but the new car hasn’t yet declared itself. It’s lurking in the background!
Old 11-03-2018, 05:43 AM   #13
BOOTLEG's Avatar
durametric?
Before I drop my bad 3.2L engine, I'd like to read any failure codes so trying to buy a diagnostic scanner with this capability. Durametric?
BOOTLEG is offline   Reply With Quote
Old 11-03-2018, 01:51 PM   #14
Legit Durametric, PIWIS or PST2.
