Old 09-09-2006, 11:54 AM   #1
B&M shifter install help!
i'm in the process of installing a B&M shifter into my 98 boxster, i have the shifter removed and the new one ready to install.
when removing the old shifter there is a white square plastic clip on the pivot ball. but the b&m unit is not supplied with this, the clip is not large enough to fit the new pivot ball, do i need the clip? it seems like there will be a lot of play if i cant get the square clip on the pivot ball.
i'm at step # 46 of the B&M intstallation sheet.
Nick-NY is offline   Reply With Quote
Old 09-09-2006, 02:53 PM   #2
There is some play, but not much. That white plastic cover will not come off, and even if it did, it wouldn't fit the B&M ball. No worries - continue with installation.
Todd
2005 Boxster S - Atlas Grey/Black, PASM, Sport Chrono, Bose
2006 Infiniti M35 Sport
2007 Cadillac Escalade (tow vehicle with bling)
'00 Boxster - 2.7l w/FVD ECU tuning, Moton double adjustable suspension, custom stainless headers, lightweight flywheel, dual Magnaflow mufflers, 18" CCR wheels, 911 front brakes in front, Boxster front brakes in rear, full welded cage.
http://www.epiqautosport.com/images/epiqtoddavatar2.jpg
EPIQTodd is offline   Reply With Quote
Old 09-09-2006, 03:22 PM   #3
Thanks, i finished the install, now the box shifts like my old Miata
I was able to get the plastic piece off, but like you said it wouldn't fit.
Old 09-09-2006, 08:08 PM   #4
B&M kit
Isn't it a nice change from stock! I but one on my box about 6 months ago and it makes shifting really feel more positive. The stock throw was soooooo long.
pecivil is offline   Reply With Quote
