Old 10-06-2018, 01:48 PM   #1
Pdwight's Avatar
Discussion question....lube on lugs
I have heard many different opinions on thus. I have heard a tiny bit of wax or lanolin, a single drop of oil. And I have heard bone dry always....just curious what guy's have heard or do ?
Dwight
Old 10-06-2018, 01:51 PM   #2
Keith Newby's Avatar
I've always used a bit of anti-seize...
Keith Newby is offline   Reply With Quote
Old 10-06-2018, 02:35 PM   #3
From the owners manual...
(But to be honest, I never follow this instruction and always install bone dry ).
Old 10-06-2018, 04:38 PM   #4
I've always used a bit of anti seize. Particularly with alloy lug nuts...
Old 10-06-2018, 08:48 PM   #5
jaykay's Avatar
Anti seize on threads.......just feel like that is what will give proper torque values and fully develop fastener strength.
Tom what do you think that note means???
986 00S
Old 10-07-2018, 10:06 AM   #6
BYprodriver's Avatar
Me too, just be sure to not over torque.
Old 10-07-2018, 03:04 PM   #7
If you over torque because you use grease or something like anti seize you can have a severe problem, because you wheels fly off.
https://youtu.be/G-6S8lVBYno
Regards, Markus
Old 10-07-2018, 04:10 PM   #8
Racer Boy
Racer Boy's Avatar
In all my years of driving, and especially racing (which means taking wheels off and putting them back on hundreds of times), I’ve never used anything on the threads, other than making sure they were clean. The end result? I’ve never had any problems.
Old 10-08-2018, 03:40 PM   #9
I think the latest factory recommendation is not to apply anything. I used anti-seize for the last 30 years for all cars I maintained and no issues, but now I just use a wire brush to clean the thread. I do use anti-seize between alum wheel and steel rotor to prevent corrosion and sticking from experience.
Old 10-08-2018, 04:11 PM   #10
Pdwight's Avatar
Regards, Markus
I do use a Torque wrench for tightening
Old 10-08-2018, 11:16 PM   #11
Topless's Avatar
My Dad was an aerospace engineer and dry threads were verboten around our house. Every threaded fitting had a light lube or anti-seize to get the proper stretch at torque spec.
Old 10-09-2018, 11:49 AM   #12
Sewing machine oil or gun lube. Very light weight oil. But then I don't have to deal with rust.
2001 Boxster
2007 Toyota Highlander
Old 09-14-2023, 08:38 AM   #13
jaykay's Avatar
Ti Stud conversion torque lubricated
If the original torque spec is 130 Nm lubricated (anti seize) and one has titanium studs with a recommended torque reduction factor for lubricant (anti seize), should this factor be applied? Is this not doubling the friction factor, torque reduction?
I suppose it all come down to whether the Porsche spec is actually lubricated as indicated by the manual below.
Should one (me) lower the factory 130 Nm for my new antiseized Ti hardware given what is wrtitten?
986 00S
