Old 09-08-2006, 03:42 PM   #3
problem solved. i was checking voltage to the transponder signal transformer; there was none. turns out the button at the center of the ignition switch was not being pressed by my ignition lock (need a new ignition lock). in the meantime, i wired a switch to 68S and 30 on the ignition switch so i can short the terminals and start the car.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
