Old 07-27-2018, 07:34 AM   #1
New rear muffler - Brombacher
Just arrived from Germany.
Brombacher "Sound" version.
Look forward to checking it out.
Anyone got experience with this?
Bruich10 is offline   Reply With Quote
Old 07-27-2018, 07:35 AM   #2
Yes, and you are going to love it :-)
Old 07-27-2018, 09:19 AM   #3
Jesus that is exhaust pipe pornography.
YellowS2000 is offline   Reply With Quote
Old 07-27-2018, 10:06 AM   #4
2ata is offline   Reply With Quote
Old 07-27-2018, 10:10 AM   #5
Right enough!
In my country we simply call it EPP!!
Old 07-27-2018, 10:12 AM   #6
"50 Years of 550 Spyder"
10/10ths's Avatar
Yes......
.....20,000 miles and sounds like a dream.
Old 07-27-2018, 10:17 AM   #7
10/10ths's Avatar
Here is.....
......what mine looks like after a couple of years.
Old 07-27-2018, 10:45 AM   #8
Wow looks great.
Also looks like you have a few mods to the underside??!!
2003 Boxster S
Seal Grey
Old 07-27-2018, 11:32 AM   #9
I had mine installed a couple of months back. Muuuch better than stock muffler. Would love even more sound though—might switch to 200 cell cat midpipes.
square-root is offline   Reply With Quote
Old 07-27-2018, 11:55 AM   #10
Got to ask: I am very familiar with the Rennline tie bar and hold downs, but what is the red thing at the rear of the triangular plate?
Old 07-27-2018, 12:15 PM   #11
WALDMEISTER
BRAN's Avatar
Very cool. Not sure, looks like a spacer to me.
Hmmm...website claims
- + 8kw (11PS) & + 15 Nm
Old 07-27-2018, 01:59 PM   #12
I have one in very nice condition for sale for $1,000 plus shipping from So.Cal
removed from my 987 '07 CS
https://www.stuttcars.com/part/770/
If required, I have additional pictures
Old 07-27-2018, 02:48 PM   #13
911monty's Avatar
Curb Feeler!
Old 07-27-2018, 02:58 PM   #14
Curb Feeler!
What I am afraid of is that is some sort of jacking point, which is nuts because it is under a non structural stamped sheet metal aluminum bracket that you can easily bend with your hands...…………….
Update: That is exactly what it is, sold by Fabspeed for the 981 cars (2013-2016), which have a different bracket above it that is considerably stronger than the one on a 986...……...
Old 07-27-2018, 03:23 PM   #15
10/10ths's Avatar
Mods.....
......Yes. You are correct, it IS nuts.
You REALLY don’t want to jack up at that point.
But that center red thing is, indeed, a jack point.
I bought and installed it for two reasons—First, it makes for fun conversations like this one when folks spot it, and Second, if I am ever in a pinch and for some reason I can’t access the jack points I should use, this spot is theoretically useable.
I travel cross-country a great deal, and I have been stranded many times and every once in awhile I have to let some tow truck driver jack the car up without me around. I figured if they decide to jack her up at that spot, I maight as well provide a pad.
Again, it’s a last resort jack point.
Mostly for the bling.
Old 07-27-2018, 03:24 PM   #16
Hopefully I will get the brombacher sound mounted next week.
Trackday coming up in Sweden next Saturday.
So I will have some experience after that that I may share.....
Happy weekend to all boxsters out there!
2003 Boxster S
Seal Grey
Old 07-27-2018, 03:59 PM   #17
Cunningr's Avatar
I am about to pull trigger on muffler order what else did you order with it? Do need to order the bracket or any other bits?
Old 07-27-2018, 04:26 PM   #18
10/10ths's Avatar
Brackets, et al......
.....They offer the clamps and brackets, it depends on the health of your current parts, I ordered them and ended up using them just because I had them, so why not?
Old 07-27-2018, 04:29 PM   #19
10/10ths's Avatar
Jack Point info.....
......as far as that rear, center jack point-----The Bentley Manual says that you CAN use that spot as a jack point.
Now, I personally do NOT use it, and I would NOT encourage others to use it.
BUT.......
Old 07-27-2018, 04:54 PM   #20
911monty's Avatar
BUT.......
No Bueno Dude. Have a look at the picture you posted and the one in the Bently manual. Three things stand out. First the spindly aluminum bracket in your pic is not the sturdy black crossmember in the Bently. Second is the cable restraintyou see in the Bently, is at the other end of the triangular aluminum pan piece mounted into that nice sturdy crossmember. Third id the engine is not behind that bracket ala a 911.That jack point indicated in the Bently is as stated near the "center" of the car. However like in the movie Field of dreams "if you supply a jack point they will use it, or something like that.
