Spacers...
Team,
What are the widest spacers I can put on a stock 986 S without rubbing. I was thinking 20mm front, 15 rear, but I want to use stock bolts for the wheel and thought I'd ask who sells a complete kit. Advice on width and sourcing would be appreciated. I have the 18" wheels. |
http://986forum.com/forums/uploads02...1527490720.jpg
All spacers will require longer lug bolts according to Porsche |
Even the OE 5mm spacers come with longer bolts.
What size wheel you running? Did I miss something? I went with ECS. Came with the extended bolts. |
I'm using 20mm spacers front and rear with the original 17" turbo twist wheels. I purchased the spacers thru ECS, they came with the correct length longer bolts.
It seems that 15mm are the most popular, which gets me thinking that wider might present an issue |
If you are that concerned get a couple of rulers and see for yourself. Measure the gap from the wheel to the outer arch liner
I run H&R 23mm spacers in the rear with both my stock 17” twists & my Carrera lights.
5mm up front, IIRC. |
If interested I have a set of 15MM with Bolts for sale. Posted in Parts for sale.
Thanks Van |
You need the longer bolts, too.
Cunningr,
Here is the For Sale post. http://986forum.com/forums/boxster-cayman-parts-sale-wanted/72172-fs-15mm-spacers.html Thanks Van |
Do these come with the 2 piece correct longer Lugbolts? |
Van |
Here are 20mm spacers on 17" Turbo Twist wheels.http://986forum.com/forums/uploads02...1528243514.jpghttp://986forum.com/forums/uploads02...1528243734.jpg
Good luck :) |
I don't have spacers, but I would think with the widest spacers you might get some rock chips on the fenders and their edges. Am I wrong...
20mm on both front and back with no rubbing?
I have a set of 15mm on the way. ECS said 15mm bout right.
Yes, 20mm on both front and rear with no rubbing.
Photo of front with 20mmhttp://986forum.com/forums/uploads02...1528308134.jpghttp://986forum.com/forums/uploads02...1528308282.jpg |
Thanks! |
Read again carefully I said no rubbing.
Lew,
I'll try to get photos from the front and back tomorrow. |
A couple more photos for Lew.
20mm Spacers on 17" Turbo Twist wheels. Hope these are helpful. http://986forum.com/forums/uploads02...1528423296.jpg http://986forum.com/forums/uploads02...1528423466.jpg http://986forum.com/forums/uploads02...1528423539.jpg |
Looking Good, Thanks!
Thanks for the pictures. I noticed your deck lid is without the Boxster emblem. Did you remove it? I recently installed the Porsche letters and I really like how it looks now.
http://986forum.com/forums/uploads02...1528426782.jpg |
Yes, I removed it.
Mine was black and I felt the trunk looked better without the faded black emblem and I am too cheap to buy a chrome one. |
Why spacers? I have the 17 inch turbo twist offset, with no need for spacers.. Sent from my iPhone using Tapatalk |
As Cunningr said, for looks, they fill out the wheel wells.
They also add a few IHP. IHP = Imagined Horse Power :) |
| All times are GMT -8. The time now is 09:07 AM. |
