Old 04-19-2018, 10:27 PM   #1
Quick coolant top off question
Replaced the WP and thermostat today... That was fun.:ah: Went through the fill/bleed process and all seemed good. Let the car cool and figured I would need to top off a bit. Which I do. Question is, is the "MAX" mark a "hot" mark, or is it ok to top it off to "MAX" cold? Can't seem to find any good answer one way or the other. Thanks!
Old 04-19-2018, 11:02 PM   #2
oldskool73's Avatar
The manual doesn't say directly, but it does caution against removing the cap while hot and the steps say 'Switch off engine and let it cool', then remove cap and fill but 'do not exceed max line', so I assume it's a cold max.
oldskool73 is offline   Reply With Quote
Old 04-20-2018, 01:44 AM   #3
still plays with cars...
BoxsterSteve's Avatar
Mine is midway between the two marks when cold.
I’ve not ever had a problem with the car spewing coolant.
Six speed 2000 Boxster S
Old 04-20-2018, 03:13 AM   #4
Cunningr's Avatar
Last Summer when Ambient temps hit 40 Celsius I had some issues with coolant overflowing until it dropped down below the max a little. Had me in panic mode.
Old 04-20-2018, 03:39 AM   #5
Multi-Boxer Driver
Deserion's Avatar
Same here. My W124's tank is marked for Cold/Hot (auf Deutsch, natürlich) and I keep it on cold (min).
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 04-20-2018, 08:17 AM   #6
Yeah, my Jeep is the same way, and prior to the WP it always sat about midway as well. Good deal!
