Old 03-16-2018, 10:44 AM   #1
lcsdoug's Avatar
its here
My Speed Yellow 987 arrived the other day. Few pictures of the unboxing as it was after 7pm and dark and cold. I had contracted with Montway and they employed OK Auto Carrier. They picked it up on time and delivered it on time. Car was in excellent shape. It was an enclosed truck and they had the car covered in plastic sheet. Excellent delivery at a fair price.
I had it delivered to my daughter's address in Wauwatosa, WI in a quiet little neighborhood with narrow streets. Fortunately there were no cars parked on the street when the truck arrived. He had three cars to remove before he could reach my car, one was a white Viper another a blue restomod 57 Chevy with no mufflers I could notice - Loud. Pretty soon lots of neighbors were out watching the show. One came over to me and said they hadn't had this much excitement here in years. Then a police car arrived said they had an anynomous call complaining about illegal parking. He came over to the crowd and said oh, sombebody's getting a car delivered. So he stayed awhile and watched with the neighbors.
Then finally he got to the boxster, and he started it up and backed it out with giant clouds of white smoke. Oh boy, what did I get. By the time it was off the truck and on the street the smoke had dissipated and I could not see any more smoke from the exhaust. Maybe the 2000+ mile trip jostled a little oil into the manifold. I've been watching closely and haven't had a repeat of the smoke so maybe it's ok.
So the second day home, I decided to install my Garmin gps. I used an Bussman ATC add a tap. They fit fine with the fuse cover on. Checking the fuse box, C1 was open and it went on and off with ignition, perfect. There was a small bolt above and the left of the gas pedal that I secured the ground wire with an M6 nut and washer. Ran all the leads up and under the left side of the dash. Nice easy install. I had the radio on and reset all the station buttons. Then I thought I would take it for a drive and test the gps. So, I put the tools away and opened the garage door, got in, turned the key and clickety click click and nothing. All kinds of error messages popping up PSM failure ABS failure something small in red I couldn't even read. I put in a gps and fried my car!
I pulled the fuse box cover and removed the add a tap. Still nothing, just a lot of clicks and error messages. Soon I didn't even get clicking. Starting to panic now. Turned everything off went inside to get on the internet to find some answers. Nothing helpful except maybe check the battery. Sounded reasonable so I opened the lid and connected my battery charger. Set it on high about 40 amps and waited an hour or so. With high anxiety I removed the charger and gave it a try. Success! started right up. Whew... What a relief. Re-connected my gps and it worked fine.
So the battery is an Interstate and 5 years old. I usually replace a car battery anyway after 5 years so I went and purchased an Everstart Maxx H7 which I'd seen recommended by a number of owners. Now before I swap this out, is there any surprise waiting? Or is this just a normal reset the radio type switch out. It's always exciting expecting the unexpected with a used car. I'm to old for many more shocks.
2007 Speed Yellow Boxster S
"Never let the fact that you don't know how to do something keep you from doing it." - Me
lcsdoug is offline   Reply With Quote
Old 03-16-2018, 11:08 AM   #2
kk2002s's Avatar
Nothing special about changing battery other then radio code.
My only challenge was hooking up vent line and that was finding a nipple that fit into battery vent hole and clear vent line fit snugly on
Why did they ship with top down??
That makes no sense
Enjoy
Seal Grey
Old 03-16-2018, 11:44 AM   #3
Congrats & welcome - looks like a beauty!
Nothing special needed for battery change (unlike newer P-cars ). Only thing needed will need be "recalibrating" the one touch windows and PSM by going for a 50' or so drive. Both are very simple procedures in the manual; you'll be set in a matter of minutes. No radio codes, no presets lost... clock might need reset but easy enough too.
Hopefully driver just put top down to pull it out for you and didn't travel topless the entire way...
Enjoy!
"Cool Prius!"
- Nobody
Old 03-16-2018, 12:09 PM   #4
Ciao's Avatar
Congratulations and Enjoy!
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 03-16-2018, 12:34 PM   #5
Super Moderator
Congrats on the new ride and welcome to the forum! The community is filled with a lot of very helpful and knowledgeable members, so you'll have plenty of assistance if needed. To help you get more familiar with the 987 and in case you're going to be working on it yourself, I'm attaching a link to our site's DIY tech articles on that platform. Please let us know if you have any questions.
https://www.pelicanparts.com/techarticles/Porsche_Cayman_987_Tech.htm
Dmitry at Pelican Parts is offline   Reply With Quote
Old 03-16-2018, 01:37 PM   #6
lcsdoug's Avatar
Thanks for the responses. He did say he put the top down so he could see what he was doing. It was darker than the pictures looked. Ok I'm off to fearlessly swap batteries. I bookmarked that 987 link, looks very helpful.
Old 03-17-2018, 06:38 AM   #7
BruceH's Avatar
Enjoy! Good battery choice, mine seem to last about 4 years. I’m originally from Wisconsin but I left about 22 years ago, no more long winters.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 03-17-2018, 06:59 AM   #8
Boxing Cat's Avatar
Weak battery can cause all kinds of strange behavior and occasional start up smoke is unfortunately normal.
You're good - enjoy!
Boxing Cat is offline   Reply With Quote
Old 03-18-2018, 07:44 AM   #9
lcsdoug's Avatar
I left Wisconsin for about 10 years, but came back, all my family and my wife's is here. I'll be driving my Porsche whenever the roads are dry and clear, which is surprisingly a lot of the time.
Old 03-18-2018, 07:47 AM   #10
lcsdoug's Avatar
The smoke on startup hasn't happened again, so I won't worry about it.
Old 03-18-2018, 08:06 AM   #11
The smoke is normal if the car has been sitting for a while or if the last time the car was started it was only ran for a short period (starting it up for 10 seconds to move it in or out of the garage, for instance).
Old 03-18-2018, 09:34 AM   #12
Congrats and it looks like you got a beauty!
If you want, you can purchase a little device that plugs into the cigarette lighter socket and has a 9v battery. If you plug that in and then do your battery swap, you won't loose any memory settings. I think the thing costs ~$5-$10. I bought one and its come in handy on our cars...all seven of them!
Keep any eye on the white smoke. Most likely its just from the car sitting while in transit. If you see it again a few times at start up, do the check for you AOS (try opening oil fill cap with car running and see if you have excessive vacuum).
