Old 01-09-2018, 02:08 AM   #1
LN Engineering Spin-On Oil filters in the EU
Hey everyone,
As I am trying to keep my 986 fed with clean oil I just ordered an LN Engineering spin-on oil filter kit ( https://www.ebay.com/itm/121844438036 ) which has two Bosch-branded filters included.
This raised an interesting situation:
Are the included Bosch filters any good or should I not even bother with them?
I'm trying to source Napa Gold 1042's or WIX 51042's from Europe but I am not having much luck. Is there some other filters which are of equal qualities for the 986 which are easier/cheaper to obtain in the EU that I should be sourcing instead?
Thanks for any and all advice you might be able to provide,
square-root is offline   Reply With Quote
Old 01-09-2018, 02:37 AM   #2
My opinion is LN Engineering would not include Bosch filters if they were crap so go ahead and use them . Bosch , NAPA Gold , Wix and Mobil 1 are all filters I would use . Because they are available to me I primarily use the Wix on mine .
rfuerst911sc is online now   Reply With Quote
Old 01-09-2018, 05:14 AM   #3
Mobil 1 works, m1-107
also K&N HP-1007
Old 01-09-2018, 05:25 AM   #4
"50 Years of 550 Spyder"
10/10ths's Avatar
Oil filters to use: Napa Gold 1348, Wix 51348, K&N HP-h1002
Old 01-09-2018, 06:40 AM   #5
Not sure if it is LN Engineerings kit or if it is the sellers kit.
Old 01-09-2018, 06:44 AM   #6
I got that kit. It's excellent! My unbiased and uninformed opinion is that the Bosch filters are just fine for our older Boxsters. I chose the kit because it included a couple of free name brand filters.
Wix 51348 oil filter is available at Amazon UK, expensive and you have to buy a dozen. On US Ebay, there's this https://www.ebay.com/itm/1348-NAPA-GOLD-OIL-FILTER-51348-WIX-Master-Pack-Of-12/162753804500?epid=1617931285&hash=item25e4e1f8d4:g:MHMAAOSwdDBZe5vC&vxp=mtr#shpCntId shipping and import duties are awful!
NAPA Gold filters are manufactured by Wix.
2001 Boxster
2007 Toyota Highlander
Old 01-09-2018, 06:55 AM   #7
My guess is that it's the sellers kit.
Here's a rating table on various filters, kinda interesting. Untitled Document It looks to me like the highest rated, by far, is the Fram (!) XG3506 or 3675. Gets an overall B+ to A-
2001 Boxster
Old 01-09-2018, 07:35 AM   #8
These? https://www.ebay.com/itm/6-PACK-FRAM-Ultra-Synthetic-Oil-Filter-Top-of-the-Line-FRAMs-Best-XG3506-/161962671106
Look (weirdly) cheap?
Old 01-09-2018, 10:59 AM   #9
Racer Boy
Racer Boy's Avatar
FRAM used to be garbage, but they have gotten their act together and are as good as other brands now. I don't have the link, but I read an article about this. They took a tour of the FRAM factory, and tested the filters, finding them to be top-notch.
That said, I still usually buy either the NAPA Gold or Wix, which of course are the same filter. But I've used Bosch many times on my motorcycle. I can't remember who makes the Bosch, but I read a test where they did well.
Old 01-09-2018, 11:17 AM   #10
steved0x's Avatar
These are the filter if the IMS Solution is installed with its version of the spin on adapter (and is a cross for a lot of Toyota filters) - I bought one a while back by accident but was able to use it on my Tacoma
  • Regular non-IMS solution LN spin on adapter - Wix 51042 and crosses
  • IMS solution spin-on adapter - Wix 51348 and crosses
Old 01-09-2018, 12:02 PM   #11
10/10ths's Avatar
Steve,
Correct. Forgive me, I didn’t catch that he was using the “non-solution” version.
Old 01-09-2018, 01:44 PM   #12
steved0x's Avatar
Steve,
I'm surprised they just didn't use the same filter for both, I think they are the same height (3.404"). The only different seems to be the thread, and that the 51042 is a full flow filter with no bypass valve and max flow of 9-11 GPM flow, and the 51348 has a bypass valve and is rated for 7-9 GPMmax flow with the bypass set to open between 8-11 PSI.
Old 01-09-2018, 03:17 PM   #13
Thanks for posting that, I bought the six pack. I had a bunch of Ebay bucks so the filters were no cost to me.
2001 Boxster
Old 01-09-2018, 08:09 PM   #14
It might help drive the oil to the IMS having a slightly lower pressure max? Good in theory anyway!
