Old 12-30-2017, 03:16 PM   #1
Center cap removal tool
If you find yourself in need of a center cap removal tool, have no fear
you can make one yourself at zero cost.
All you need is a simple metal coat hanger, a pair of pliers and a pair of side cutters.
Tools all of us likely have or at the very least should.
Cut a 6" length of coat hanger. Bend it in half, leaving enough room for your finger
to fit. Now, bend the ends, approximately 1/4 " at a 45º angle. Done. Bend it slightly
to match the removal hole spacing and you're all set.
2001 Boxster S, Metallic Black, 6 Speed Manual, 3.2 liter engine.
RobertKing is offline   Reply With Quote
Old 12-30-2017, 04:12 PM   #2
Ciao's Avatar
Great tip and savings!
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 12-30-2017, 05:02 PM   #3
1997 Tip, 2018 Macan
rexcramer's Avatar
Well done sir. A couple of allen wrenches will do in a pinch also.
Old 12-30-2017, 07:40 PM   #4
I find it's pretty easy to just tap them out from the back side of the wheel. What are the reasons for removing the center cap and not be taking the wheel off at the same time? I suppose you could be swapping out center caps...
deathsled986 is offline   Reply With Quote
