Old 11-18-2017, 05:11 PM   #1
AOS failure!
Hello, I have a AOS question? Would oil exit the exhaust pipe if the AOS goes? I'm looking at a 2002, Boxster with a possible blown motor. After doing some research, I think it has a bad AOS! I haven't been able to see the car ( owner is away) so I can't perform any test ( compression, vacuum, or change the oil) So I'm thinking, depending on what the owner was doing ( how hard he was driving) it would be possible for oil to exit the exhaust! Any information or opinions? Thanks!
peku800 is offline   Reply With Quote
Old 11-18-2017, 05:58 PM   #2
In order for liquid oil to make it through the engine and out the exhaust, something very unpleasant has probably occurred. Pull the oil filter and look for debris; if you find it there, the engine is done.
Old 11-24-2017, 08:06 AM   #3
Administrator
Moved to the discussion forum. Don't forget to check out our articles for help as well. Good luck!
http://www.pelicanparts.com/boxster/boxster_tech.htm
Luccia at Pelican Parts is offline   Reply With Quote
