Old 11-10-2017, 07:45 AM   #1
Front End Noise when hard turning
I have started hearing and feeling a rumble noise from the front end when going in a hard turn. What could this be? I am going to replace my brake pads today so I would like to know what I should inspect while I'm in there. Thanks for any advice.
blvsmith is offline   Reply With Quote
Old 11-10-2017, 08:04 AM   #2
kk2002s's Avatar
With the pads out listen to the wheel bearings as you freely spin them. The sound you describe while turning indicates to me that a wheel bearing is starting to protest
Seal Grey
Old 11-10-2017, 08:12 AM   #3
Definitely a wheel bearing.
Old 11-10-2017, 08:32 AM   #4
OK great I'll look and update thread when I find out. Thank's for the advise.
Old 11-10-2017, 10:01 AM   #5
I took my front pads out and found a back plate inserted behind the pads. Do I re use it buy new ones or just go in with new pads minus the anti squeal backing plate?
Old 11-10-2017, 10:42 AM   #6
steved0x's Avatar
I always reused mine by cleaning them off, spraying some anti-squeal spray on the backs of the pads, re-insert the backing plates into the pistons and then slide the pads down into the slot.
Old 11-10-2017, 11:49 AM   #7
OK great that's what I'll do thanks
Old 11-11-2017, 07:12 AM   #8
With the wheels off and brake pads out should there be any play with the rotor?
Old 11-11-2017, 07:46 AM   #9
the rotor, if it still has its retaining screws, should not move laterally. If it moves when you grab it and rock it back and forth (obviously not the steering moving), then you have a bad wheel bearing.
Old 11-11-2017, 08:43 AM   #10
OK that's it then rear drivers side will check the rest when front brakes come in. Thanks!
