Old 08-19-2017, 11:47 AM   #1
Front badge popped off
Looking for advise on what to use to stick back the pins on the front badge.
I tried epoxy but that was a no go.
Tuffty_Nut is offline   Reply With Quote
Old 08-19-2017, 03:02 PM   #2
steved0x's Avatar
I think they are soldered on at the factory but I don't know what kind, this sounds crazy but a plumber might know as I think.they do some soldering.
Good job on not losing the badge
Old 08-19-2017, 03:36 PM   #3
I'm wondering if they are soldered before plating, hopefully someone else may have a suggestion.
Old 08-19-2017, 04:08 PM   #4
I am my own mechanic....
Timco's Avatar
Unless you use some super human strength glue it's toast. Solder or braze would melt the face and discolor it I promise you. These things get plated after that process.
Shoe goo is some of the best setting and sticking stuff I've used but it's not for such a small surface area. That likely won't glue.
'08 VW Touareg T-3 wife's car
Old 08-19-2017, 05:11 PM   #5
1997 Tip, 2018 Macan
rexcramer's Avatar
Anybody like JB Weld?
Old 08-19-2017, 05:16 PM   #6
So basically I have two options, buy a new one or epoxy it to the hood.
Old 08-19-2017, 05:20 PM   #7
Those posts will never solidly reattach without proper brazing, and as said, that would destroy the finish and enamel. I would just forego the posts and use a moderate adhesive to stick it to the hood. Permatex Black Silicone Adhesive Sealant would be perfect (great bond without being permanent or damaging the paint).
Old 08-19-2017, 05:24 PM   #8
That's awesome, thank you, I'll stick the pins on with epoxy and stick the badge on with permatex !
Old 08-19-2017, 05:59 PM   #9
Motorist & Coffee Drinker
78F350's Avatar
Just buy the one I have listed somewhere in the classified section in my listing for center caps.
Old 08-20-2017, 08:39 AM   #10
Nine8Six's Avatar
^ this
Epoxy; you need to grind to the bare metal 1st bud. Bond must be made with a metal-to-metal category epoxy, make sure of that. Degreasing the surfaces around is paramount also (use acetone). Re-assemble at room temperature (read label) and there is technically zero reason it wouldn't work as good (even better) than a industrial weld.
Give a call to your regional 3M Corp rep if you don't believe me
Careful with the grinding (dremel-a-lizing whatever you'll end up using). Try to keep the tolerance of the posts near intact, if you can (gods are good at these sort of things)
Precision/hard job but can be done
Old 08-20-2017, 02:41 PM   #11
I'll take it
Old 08-20-2017, 08:04 PM   #12
78F350's Avatar
Originally Posted by Tuffty_Nut View Post
I'll take it.
Pm replied, I'm currently about 1,200 miles from home and will ship it when I get back.
Usually better to replace with the right part than make a mess trying to rig it.
Old 08-20-2017, 09:56 PM   #13
BirdDog's Avatar
I'm with particlewave on this one - if it were me I'd use Permatex Black Silicone Adhesive Sealant - the stuff works great, handles heat and vibration. I'm currently using it to hold my passenger headlight corner piece in...
But if you can get an inexpensive used replacement, that might be a good move too...
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
BirdDog is offline   Reply With Quote
Old 08-21-2017, 07:14 PM   #14
Pdwight's Avatar
UUUhhhh
01 Boxster RWD Porsche 986 EMBLEM BADGE SEAL CREST 99655921100 81,360 | eBay
Old 08-22-2017, 03:45 AM   #15
Double sided 3m emblem tape or adhesive would be a good solution as well. I've used it and it sticks with amazing tenacity.
Disaster is offline   Reply With Quote
Old 08-22-2017, 07:08 AM   #16
I think the metal on metal epoxy recommended by Nine8Six would work. For those of us running his GT Collection center caps, that is what's keeping the center crest emblems on.
Old 08-22-2017, 02:27 PM   #17
Have you tried a decent super glue as that should hold it?
Saxosim is offline   Reply With Quote
