Old 04-26-2017, 03:24 AM   #1
Wheel spacers
Now to be honest, this is for my sons 2001 miata. I tried the miata board with no action. Is there a general rule on how to know what wheel spacers will fit. I've seen 1". And .75" spacers for sale.i have no idea where to start.
Thanks in advance.
DWBOX2000 is online now   Reply With Quote
Old 04-26-2017, 04:01 AM   #2
Thanks in advance.
Depends on how wide the wheels are, offset and the look you want really.
That986 is offline   Reply With Quote
Old 04-26-2017, 07:48 PM   #3
1997 Tip, 2018 Macan
rexcramer's Avatar
There is a point of diminishing return with spacers. Wider is good but, too wide is hard on wheel bearings. Also, don't forget longer studs or lug bolts to hold the wheels on.
Old 04-27-2017, 06:03 AM   #4
steved0x's Avatar
On my son's miata, the wheel studs are just exactly long enough for the OEM wheels. He got a set of 1" spacers from somewhere that had integrated studs and bolt on using the original studs. It looks pretty good but he is also lowered on coilovers. It looks really good but in my opinion it is slower on the track now, and rubs. But he likes it I don't know if his particular spacers would look good without the lowering.
Old 04-27-2017, 06:28 AM   #5
Avoid that type spacer like the plague. You're introducing another joint into your drivetrain right where it's not needed.
Old 04-27-2017, 07:16 AM   #6
BruceH's Avatar
Wheel Offset Calculator | 1010Tires.com Discount Online Tire and Wheel Store
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 04-27-2017, 12:20 PM   #7
Thanks everyone. Helpful as always.
Old 04-27-2017, 01:00 PM   #8
Thanks in advance.
I sold my Miata when I got the Boxster. Spacers are a bad idea. Much better to get wider lightweight wheels. 949Racing makes a really nice set. Konig also makes some inexpensive nice wheels. Good-win Racing is a great source.
Disaster is offline   Reply With Quote
Old 04-27-2017, 05:25 PM   #9
Thanks, I will let him know.
Old 04-27-2017, 06:57 PM   #10
YW. FYI, The 949 Racing 8" wheels fit with no fender bending.
Old 04-27-2017, 07:44 PM   #11
njbray's Avatar
My car came with Porsche supplied spacers - 7mm front and 12mm rear. I think this is the size they recommend if you want spacers. Anything bigger may put a lot of water on bearings.
njbray is offline   Reply With Quote
Old 04-27-2017, 11:53 PM   #12
There's a lot more to it than that as it would depend on the offset and width of wheel.
Old 04-28-2017, 09:59 AM   #13
njbray's Avatar
That's correct - I should have mentioned that. My wheels are standard offset / width. So the spacers are basically cosmetic - although I guess the wider track may help a bit.
Old 04-28-2017, 10:29 AM   #14
steved0x's Avatar
The 949Racing 6UL wheels are very nice, my son has a set of them, he has the 15x7. 949Racing is working on some 5x130 Porsche fitments for some new 18" wheels coming out, but not any 17's unfortunately.
