Old 04-15-2017, 01:58 PM   #1
Name this oil leak
So I bought a leaking '01 S with the PO diagnosis that it was a RMS. That's a pretty fair bet most of the time with oil in the ground from the center of the car, right where engine and trans meet. But the right rear wheel seemed to have a lot of oil on it also... Today I got the car in the air and this is what I found. Could the AOS be bad also or is this just the AOS? I'm pulling the trans and doing IMS and RMS regardless, but looks like I might need to do some work up top also.
CBRacerX is offline   Reply With Quote
Old 04-15-2017, 02:09 PM   #2
911monty's Avatar
Cool!! I love these posts. My WAG is actually something you may like better......Leaking oil fill tube. What do I win? :dance:
Old 04-15-2017, 02:10 PM   #3
I will add there have no classic AOS symptoms (crop dusting from the exhaust) and the car runs fine.
'01 986S
‘07 GT3
'80 911SC Weissach Edition (Sold)
‘11 958 S
https://dergarage.com
Old 04-15-2017, 11:15 PM   #4
78F350's Avatar
Aside from the AOS being bad, one of the tubes connected to it might not be fully seated. That way, you get the mess, but not the classic AOS symptoms.
Old 04-16-2017, 06:20 AM   #5
CBR:
Perhaps be a good idea to first clean everything before you remove the transmission just to confirm the source of the oil leak, this also would make the gearbox removal process much more pleasant IMHO…
Good luck!
Old 04-16-2017, 08:33 AM   #6
I am my own mechanic....
Timco's Avatar
Captain Underwood, is that you??
I'd clean up all around first. As noted, trans pull will be easier and cleaner.
'08 VW Touareg T-3 wife's car
Old 04-17-2017, 04:41 AM   #7
Cleanup is a given folks, I don't like getting any dirtier than needed. I'm a fan of Total Cycle Cleaner for messes like this. I've gotten a good look at the AOS and it is clean and looks new. So the mystery continues...
Old 04-17-2017, 05:49 AM   #8
nice picture
which kind of scissor lift do you have?
It seems that the height is more than a adequate, it is pretty stable?
Old 04-17-2017, 06:07 AM   #9
It is a Mohawk and very stable. Done many engine R&R operations with it on 911's of all sorts and a few with 987 platform. This is the first 986
Old 04-17-2017, 03:14 PM   #10
power steering leak?
loose oil filler tube?
email beats Private Messaging: rwalker@rwalker.com
cornholington is offline   Reply With Quote
Old 04-17-2017, 06:59 PM   #11
It's motor oil. I'll take a look at the oil filler tube when I remove the top engine cover shortly.
Old 04-18-2017, 05:45 AM   #12
Thanks CBR!
I am considering a lift because going through the lengthy process to get the car on jack stands (properly and safely) its getting old.
Perhaps I am the one getting old..
Regards, Gilles
Old 04-18-2017, 06:11 AM   #13
steved0x's Avatar
Thanks CBR!
Regards, Gilles
I think it is us. I can get the car on the lower heights of the jackstands with only 2 lifts of the jack (and with 3 lifts I can go higher), but yet I am tired of all the getting up and down off the hard garage floor to make sure everything is lined up and am day dreaming about a lift as well...
Old 04-18-2017, 06:00 PM   #14
Looks like RMS
'01 986S
‘07 GT3
‘11 958 S
Old 04-18-2017, 06:01 PM   #15
And oil fill tube! I am not familiar with that one, so I'll have to look for all the parts and order accordingly.
'01 986S
‘07 GT3
‘11 958 S
Old 04-18-2017, 06:07 PM   #16
Jager's Avatar
Pictures of the top side?? Check the Oil Cooler... Those O ring seals go bad after time.
Jäger
300K Mile Club
Old 04-18-2017, 06:13 PM   #17
Oil cooler is not leaking. Topside pics are a few days away.
'01 986S
‘07 GT3
‘11 958 S
