Old 03-26-2017, 05:07 PM   #1
Triple Blink Turn Signal Relay
I did this mod on my 996 and it worked out great. Has anyone tried it on the 986 yet? After driving my "new" 2001 986 for a couple days I really miss having the trip of blank feature.
3-Blink Turn Signal Relay Mod - 6SpeedOnline - Porsche Forum and Luxury Car Resource
CBRacerX is offline   Reply With Quote
Old 03-27-2017, 08:04 PM   #2
Coaster's Avatar
I had my shop install the Audi part (electrical is not my strong suit). As far as I can tell, 3 blinks every time.
Coaster is online now   Reply With Quote
Old 03-28-2017, 04:45 AM   #3
I am my own mechanic....
Timco's Avatar
Quite a while ago I made a thread about this. I'd love to have this feature.
'08 VW Touareg T-3 wife's car
Old 03-28-2017, 06:41 AM   #4
Luckyed
Luckyed's Avatar
My 2007 Cayman S had that feature.
I liked it a lot......
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
Luckyed is offline   Reply With Quote
Old 03-28-2017, 06:53 AM   #5
Chuck W.'s Avatar
Cool, thanks CBRacerX for posting this. This should work on our Boxsters the same as 996s. The dash wiring is the same. The removal of the emergency flasher is different only in the fact Boxsters don't have a trim ring around the switch. The wiring and instructions look a tab daunting, but I think once you get in there it will make more sense.
I just purchased a kit off of eBay;
On eBay for $9.09;
3-Pin Car Flasher Relay Fix LED Turn Signal Light Hyper Flash For Both CF13 CF14 | eBay
And, $9.99;
1995 Porsche C4 Cab
Old 03-28-2017, 07:53 AM   #6
I don't get it. You posted the same link twice and neither is a 3 blink relay.
FYI: all of the Audi relays I found were $75-$100, and you still have to do a lot of wiring.
You could save yourself some trouble and just buy a plug-and-play one touch flasher relay. I've seen them for around $50, but I'm sure they can be found cheaper.
No need to do all that crazy wiring. Just pop in the relay and you're done.
Old 03-28-2017, 09:45 AM   #7
Coaster's Avatar
I bought my kit for $51, They had to move 5 wires from the switch to the new switch and it integrates in the emergency flasher harness.
Old 03-28-2017, 10:15 AM   #8
I actually just found some in the $30 range. Some require wiring into the turn signal wire, some are just a relay that replaces the existing relay (a 10 second job). I'm sure an Asian distributor has something under $10, but I've lost interest.
I prefer to just hold the lever in the not fully engaged position until I'm satisfied. Our Mazda has the one touch triple blink and half of the time I use it, I end up fully engaging the turn lever anyway, so it's not really very convenient. I also don't think 3 blinks is adequate. I'd prefer 4-6.
Old 03-28-2017, 11:03 AM   #9
If you can let me know where you got it for that price I would appreciate it. I've only found for $72.
Old 03-28-2017, 03:40 PM   #10
Coaster's Avatar
FYI PM sent.
