Old 06-26-2006, 01:05 PM   #1
Extra stiff clutch question
Hi all!
I am looking for some opinions regarding the clutch on 2001 Boxster S (28K miles). I have read all closely related threads, but I haven't been able to find a definite answer.
My clutch pedal is very stiff. It makes long drives both frustrating and painful. I had my mechanic, a specialist in racing Porsches, take a look. He agreed that the clutch is stiffer than it should be. He also tested the car for slippage, but he was unable to make it slip at either high or low revs.
I asked him what might be causing the problem, and he said that he can only guess that the pressure plate might have experienced some high heat and became stiff. He doesn't think that the clutch is worn.
I am confused by his comments as well as what I have read.
Does a stiff clutch indicate it's time to replace the clutch assembly?
What does the clutch boost spring do under the dash? Could it be the problem?
Could the clutch cylinders need bleeding?
Wouldn't high heat make the pressure plate softer rather than stiffer?
Is there anything else I should check before having the clutch replaced?
Your thoughts and comments are sincerely appreciated!
- Mike -
01S
K80Kid is offline   Reply With Quote
Old 06-26-2006, 01:56 PM   #2
I had the exact same question last month. My car (2001 S) has about 21k miles on it and the clutch is stiff. Not fun in traffic, that's for sure.
http://www.986forum.com/forums/showthread.php?t=6010
-David
1996 993TT - current
2001 Boxster S (sold)
19" SSR GT3 - Cross coilovers - Custom Magnaflow exhaust - B&M Short Shifter - EVO intake - GT3 Seats - Hardtop
http://www.emeraldcitycustoms.com/images/box2.jpg
1986 Carrera (sold)
David_J is offline   Reply With Quote
Old 06-27-2006, 07:46 AM   #3
No ideas? No comments?
Old 06-27-2006, 08:31 AM   #4
Brucelee's Avatar
My only comment is that I have had two boxes with the stiff clutch. My local dealer recommended replacement in both cases.
28K is low miles for this but not unheard of I think.
You could PM Doc Willen.
Rich Belloff
