Old 02-16-2017, 07:09 AM   #1
Jay
Front trunk opening issues
Hi All,
When I press button on the key or hit the Trunk opening button, I hear the clicks and it seems like the trunk is opening. However, it does not open enough to insert fingers in to slide the middle lock/lever.
It does create some space on the sides where I can lift it up by an inch or so and then I can slide my finger to slide the lever.
Any ideas or tips to troubleshoot this issue will be greatly appreciated.
Regards,
Jay
2003 Boxster-S.
Black with Tan interior.
jay2015 is offline   Reply With Quote
Old 02-16-2017, 09:40 AM   #2
Project Addicted
jcslocum's Avatar
Lubrication ease of movement. Do the struts hold it up OK?
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 02-16-2017, 09:48 AM   #3
Grease gets old. Clean the lock release mechanism in lumber it. Cold weather probably adds to the problem.
Blackcloud is offline   Reply With Quote
Old 02-16-2017, 09:50 AM   #4
That should read "lube it". Darn spell check!
Old 02-16-2017, 10:17 AM   #5
Multi-Boxer Driver
Deserion's Avatar
It also may be possible that the actuator is failing. This happened on my '04.
Just something to look into if the other methods don't help.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 02-16-2017, 03:48 PM   #6
Damn Yankee
TeamOxford's Avatar
Originally Posted by jay2015 View Post
Hi All,
Regards,
Jay
Common and classic symptoms of a worn out spring in the hood release. The entire assembly must be replaced. Easy DYI job. You can buy a new one, or get a used one from a recycler like Woody.
Just sayin'...........
TO
Old 02-28-2017, 07:35 AM   #7
Jay
Thank you all, I lubed the latch mechanism and it took care of the problem.
2003 Boxster-S.
Tags
front trunk , frunck
