Old 12-25-2016, 12:07 PM   #2
AZ986S's Avatar
That looks like engine coolant. Can't say where it's coming from. You'll likely need to clean/dry it up, crawl under with a flashlight (with goggles) and pinpoint the source. Likely a hose or seal.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
