Old 10-13-2016, 04:03 PM   #1
joekluger's Avatar
Fuel rail question
I'm putting back my 2000 Boxster engine and can't figure out what connects to the fitting on the fuel rail on the passenger side. Drivers side goes to the fuel pump but the other rail has the same same fitting but i have nothing to connect to it. Help
joekluger is offline   Reply With Quote
Old 10-13-2016, 10:55 PM   #2
CEL P0306
This might help. From workshop manual.
#10 = Fuel return line. Tightening torque 18 +/- 3.5 ftlb.
aczyzewski is offline   Reply With Quote
Old 10-14-2016, 06:46 AM   #3
joekluger's Avatar
too small to read
can you supply a link or just let me know what it connects to. thanks
Old 10-14-2016, 01:19 PM   #4
Here is a link to the parts diagram: ******************************************** Boxster Fuel System
Old 10-16-2016, 06:43 AM   #5
joekluger's Avatar
Found it.. Thanks for your help
Old 01-20-2021, 04:03 PM   #6
I am trying to remove the fuel rails from my '98 Boxster (2.5L). I loosened the fuel line connection (nut) on the driver's side (#10 in the diagram below) and the fuel line separated from the fuel rail easily. However, i've backed the nut entirely off of the threaded part on the passenger's side but the fuel line (#16 in the diagram below) will not separate from the fuel rail. Is this a compression fitting that is stuck? I don't want to pull too hard and ruin the fuel line. Any help would be appreciated.
lawren is offline   Reply With Quote
Old 02-01-2021, 03:46 PM   #7
Well I think I may have screwed up. As I mentioned in my previous post, the connection of the fuel line (I believe the pressure line) to the passenger side fuel rail would not separate, even after loosening the nut all the way. I believe the name of the type of connection that is used and that was stuck is a "globe-seal" type of connection. I tried all kinds of spray lubricants to help loosen the connection but none of them worked. I ended up cutting the fuel line right at the fitting (bad mistake?) so that i could remove the fuel rails from the car and get it over to the bench to try to free the metal connection from the fuel rail. It actually required putting the fuel rail in a vise and vise grips on the globe seal male fitting before i could apply enough torque to break it loose from the fuel rail. I guess fuel residue had turned into some kind of adhesive over the years?
Anyways, a new replacement fuel line is hard to come by (Part #98620126700). It appears that they are all on backorder and it is unknown when they might become available.
Two questions:
1. Does anyone know where i can source a used fuel line? or
2. Has anyone replaced the line with any kind of a non-factory setup or made a repair to the fuel line. Based on my research, there appears to be a lot of reluctance to do anything but replace with factory.
Race/track season is quickly approaching and I've got to get a SAFE repair done soon.
Old 02-02-2021, 09:04 AM   #8
lawren,
I have one from a '98 I'm willing to sell. I'll get a picture of it this evening and send you a PM.
Hudy
Hudy is offline   Reply With Quote
Old 02-02-2021, 02:39 PM   #9
Thanks but I actually ended up finding someone who can get 1 of the few remaining in the US. Should be shipped tomorrow. We will see. If there is any sort of delay i will cancel order and contact you.
Old 02-05-2021, 04:53 AM   #10
Originally Posted by Hudy View Post
lawren,
Hudy
Hudy, I am interested in purchasing the fuel line that you have. I sent you a PM.
