Old 06-06-2006, 02:34 PM   #1
986 S 90k service where?
hi,
coming close to 90k on my 986 S. What does the 90k service involve? where should i have it done? how much should i expect to pay?
...oh, i live in LA area
thanks
luca
lucazuma is offline   Reply With Quote
Old 06-07-2006, 03:48 PM   #2
....hmmm
i feel no love
Old 06-07-2006, 03:55 PM   #3
1,200 miles on mine; I can't help you nor will I ever see 90K
But I did read your post!
Mantis - Atlanta area
2006 Boxster S
2005 Cayenne S
Mantis is offline   Reply With Quote
Old 06-08-2006, 03:49 PM   #4
...thanks Mantis!
Old 06-08-2006, 04:05 PM   #5
TriGem2k's Avatar
Send a message via AIM to TriGem2k
Originally Posted by lucazuma
hi,
thanks
luca
Well 30K 60K 90K are all major services. I honestly would just take it to a dealer. I use Beverly Hills Porsche (Service adviser is Eric). Your probably looking at $800+.
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
Old 06-08-2006, 09:00 PM   #6
i dont know for sure but...
you should:
change oil & filter
airfilter
pollen filter
change spark plugs
bleed brakes
I think there is some poly rib thingy that gets replaced round that mileage. i could look this up, but i dont feel like it. its probably in my owners manual, but thats all the way in the garage.
Aw S$%# now i feel like an @#$#!!%!! Fine Ill go to the garage. Are you happy now?
Hold on
OK
poly rib should be replaced at 60k, did you do it?
at 90k you also need to change your manual transmission oil or if you have a tip,
change the ATF and ATF filter and also
change the oil in the differential
there! you made me get up! i hope your happy
Finallygottaporsche is offline   Reply With Quote
Old 06-09-2006, 02:27 PM   #7
you should:
change oil & filter
airfilter
pollen filter
change spark plugs
bleed brakes
Hold on
OK
...well, thanks for the effort there! hope you didint have to take a shower after the sweat
i keed, i keed
greatest thing of boards like this one is how much you can learn from eachothers experiences and support rocks!
... i own and love 2 Ducatis at the moment and if a have learned something its that dealer doesnt necessarely mean quality. Lots of "official dealers" do terrible things to your bikes without you knowing it...untill its too late...
in my experiance i have found EXELLENT indipendent service that is usualy better than the "official" dealer service at a much lower (yeppie) cost.
also, i have lerned that certain things can be taken care of by your self and cerain others (see desmodromic valve adjustments) are better not to mess with
that saied, i have gathered intelligense on how to perform oil, filter, spark plugs change...
you guys think its a good idea to perform these maints on my own?
how a bout brake bleading/pads substitution? d.i.y. or mechanic?
and if mechanic is recomended, which one?
i have heard good things about TRE...anyone knows them?
and what is the poly rib? i bought the car used with an additional coverege for 2 years or 24k and there is no record on services after 30k...assuming the guy found an indy. Cant say if rib was changed...
thanks for the info so far!!!
ps:Finallygottaporsche, if you happen to pass along these ways ill get you a beer...or 2
Old 06-10-2006, 11:32 PM   #8
two words: "spell check"
Old 06-11-2006, 02:44 PM   #9
Major Service at 90k
Read out DTC Codes
Check Polyrib belt
Change oil and filter
Replace spark plugs
Visual inspections to engine (oil leaks, fluid leaks, coolant hoses, etc)
Replace air filter
Replace cabin filter
Check all fluid levels (brake. power steering, etc)
Check parking brake
Check pads and rotors for wear
Brake hoses and lines inspection
Check clutch play and pedal end position
Check throttle actuation
Visual inspection of steering gear, tie rod ends, etc
Inspect play in CV axles
Inspect exhaust system
Tire and spare inspection for wear
Check doors, locks, safety releases for proper operation
Check vehicle lighting
Washer fluid and windshield wiper inspections
Test drive.
There are a few things I left out, but most were visual inspections of systems etc.
Karl Wilen
RennsportKC
PorscheDoc is offline   Reply With Quote
Old 06-11-2006, 04:45 PM   #10
Brucelee's Avatar
Good job doc!
Rich Belloff
Old 06-11-2006, 05:56 PM   #11
cats...im italian and really lazy...sorry
but thanks for the info guys..
