Old 07-31-2016, 08:24 AM   #1
Lessons from Replacing my Ignition Switch
In the hope that others scratching their heads at the same point in the process may find these points of use
Don’t even think of starting this without having a tiny screwdriver. I had difficulty finding one (even tried cutting one down) and got lucky in a hardware store where a customer heard my plight and offered to loan me one out that he had magically in his glove box!
In case you’re wondering, the screws holding the electronics of the switch come out in a downwards direction. Yes, the blob of sealant you see (barely) is the head of the screw.
I did mine both from above and below the dash. Just couldn’t work it otherwise
If you try to remove the vent on the dash the first snag you encounter is taking the knob off the light switch. There is a tiny almost invisible metal tab just below the lip of the knob. I finally figured it out when I saw this post and picture (about 3 pics down):
DIY Head Light Switch Remove and Replace - 6SpeedOnline - Porsche Forum and Luxury Car Resource
The torx screw that is only accessible when you have the knob off is the same size torx as the other two
When re-installing the switch, attach it to the harness first. The pressure from the harness will keep it from falling out as you try to tighten the set screws
If you remove the snap in cover to the left of the ignition switch, note that it has a top and putting it in upside down will result in a poor fit and not follow the dash contours
If you do go in from the dash, let me know if you were able to reinsert the Phillips screw that holds the “L” shaped duct in the dash. For all the vaunted German engineering, it would have been nice to have some guide posts to help line it up. I finally despaired of ever getting the screw in and just friction fit it to the lower duct and the dash vent
Start to finish (with a hardware store trip in there) was 2.5 hours
Carlos
Cbonilla is offline   Reply With Quote
Old 07-31-2016, 08:35 AM   #2
Thank you for taking the time to post these tedious details.Missing any one of those little "Gotchas" would be a real nuisance.
Old 07-31-2016, 02:17 PM   #3
Chuck W.'s Avatar
I agree, thanks. I am big on searching the forum be for I start a project and reading all I can. This will help.
1995 Porsche C4 Cab
Old 07-31-2016, 09:20 PM   #4
flaps10's Avatar
I used a cut down eye glass screw driver. If you pull the driver seat you can lay on your back and see okay. That duct is a bit of a pain but keep at it, youll get it all back
Old 08-01-2016, 05:14 AM   #5
Xpit77's Avatar
I used this. The little driver has a light. The driver separates from the tip caddy. It`a about 2.5 ". I removed the vent.
I read where someone had a flex driver. That would be the best tool IMHO.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
Old 08-01-2016, 08:28 AM   #6
Project Addicted
jcslocum's Avatar
I found this to be very effective when doing this job.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
