Old 07-12-2016, 08:45 AM   #1
Covboy's Avatar
Hot Start Problem
Hi I have a 986 2004 2.7 Tiptronic S, with an engine hot start problem.
It normally starts from cold fine, but when its warm you turn the key and it turns over fine but does not fire - turn off then turn key again and it fires up perfectly.
Any idea's? or come across this before?
Help would be appreciated.
Many Thanks.
Covboy is offline   Reply With Quote
Old 07-12-2016, 09:43 AM   #2
Check you crank position sensor, they are famous for causing hot start problems.
Old 07-12-2016, 01:36 PM   #3
Covboy's Avatar
Many thanks, any idea how much to fix it, roughly?
Old 07-12-2016, 03:09 PM   #4
Steve Tinker's Avatar
Use the search function "cps" or "crank position sensor". the results (many) will give you an idea of how difficult it will be to replace (reasonably simple) if you are handy and don't mind getting your hands a little dirty.
Try Porsche Parts, Spares And Porsche Accessories: Retail And Trade: National; Worldwide Delivery | Design 911 for pricing.
2001 MV Agusta F4.
Old 07-13-2016, 10:57 AM   #5
Covboy's Avatar
Thanks Steve
