Old 06-01-2016, 10:38 AM   #1
Luv2Box's Avatar
Opinions On Noise From Motor
1999 Boxster 2.5L, Tiptronic, 120K miles, LN IMS, no codes present, no oil leaks, no loss of performance.
Sorry for the poor video quality and the noise I'm referring to is the consistent chirping noise that is coming from the passenger side. The last time I heard this noise it was a loose spark plug that had not been torqued by the mechanic. My current mechanic claims it is an exhaust valve that is not closing properly so I had an oil and filter change and Swepco put in to see if it is a hydraulic issue and it can be resolved. Oil used is Mobile 1 5-40 wt. as recommended by LN. The noise can be intermittent and some days is twice as loud as the video and some days I can't hear it until the car is warmed up. Not trying to second guess my current indy because he has been working on Porsches for a long time and is well known and popular with performance car owners in Monterey, just want to get a second opinion from someone who has had a similar noise.
https://photos.google.com/photo/AF1QipP-zXmT7Qbz94BfGk77PBJgZ_4kihPJ7R7BgLIY
Try this link, I just put it on "share" so hopefully it will work. Thanks for the heads up.
https://goo.gl/photos/xvw2mt8Dnqp5okjd9
Luv2Box is offline   Reply With Quote
Old 06-01-2016, 11:09 AM   #2
link isn't working for me
Woody
Old 06-01-2016, 02:09 PM   #3
stelan's Avatar
second link works for me but can not hear anything weird
stelan is offline   Reply With Quote
Old 06-01-2016, 02:45 PM   #4
Luv2Box's Avatar
It's a consistent chirp and I'm probably used to hearing it louder so it's easy for me to detect it at the recorded level.
Old 06-01-2016, 02:50 PM   #5
Mig
I would remove the accessory belt and spin the various components by hand. I suspect one of those components is making the noise possibly due to a bad bearing. Check the belt while you're at it too.
Mig is offline   Reply With Quote
Old 06-01-2016, 03:06 PM   #6
+1 almost definitely a bad bearing on the idlers are on of the accessories.
specboxCO is offline   Reply With Quote
Old 06-01-2016, 04:58 PM   #7
Known Gearhead
imon_2nd's Avatar
Sounds like a pulley bearing to me, too.
Spinning components without the belt on may not work because there will be no load on the bearing. A stethoscope may help you zero in on it while the car is running.
2004 Boxster S
imon_2nd is offline   Reply With Quote
Old 06-01-2016, 05:29 PM   #8
I am my own mechanic....
Timco's Avatar
Take the belt off.
'08 VW Touareg T-3 wife's car
Old 06-01-2016, 05:31 PM   #9
BYprodriver's Avatar
LN won't recommend Mobil 1 or Swepco in your oil.
Old 06-01-2016, 05:50 PM   #10
+1 specboxCO and Imon_2nd. That is an idler pulley.
Need_for_speed is offline   Reply With Quote
