Old 03-14-2016, 12:03 PM   #1
Muskoka Minute's Avatar
Rear Windscreen
I have a 2004 SE with wind screens.
I have read on the forum some where that you should remove these when your parked or someone might do if for you.
I thought I read that they came with a storage case?
Can anyone confirm one way or another if this is the case.
Thanks Bart
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
Muskoka Minute is offline   Reply With Quote
Old 03-14-2016, 01:26 PM   #2
still plays with cars...
BoxsterSteve's Avatar
I only run with them and the center blocker in the spring and fall.
All summer they stay in the garage cupboard.
If you want to use 'em, you could put the top up when you leave the car parked or put them in the trunk.
Mine have no storage cases, but I had a soft case made for the clear plexi blocker.
Six speed 2000 Boxster S
Old 03-14-2016, 01:47 PM   #3
use black Silicone II,
"glue" it in, it's temporary, you can pry it loose or use dental floss, but it's a pita, and takes more time than a theif wants to spend.
but a few minutes after it's out you can rub all the silicone off.
in the clips it's invisible, just clean it all well first.
and it won't rattle anymore.
Sassmatt72 is offline   Reply With Quote
Old 03-14-2016, 01:53 PM   #4
oldskool73's Avatar
The plexiglass bit originally came with a simple soft cloth bag for storage. They pop up on ebay from time to time.
oldskool73 is offline   Reply With Quote
Old 03-14-2016, 01:57 PM   #5
Gforrest2's Avatar
When I first got my Boxster, and what I read on this forum and how expensive these items were, I got paranoid and removed them every time I left the car (I keep the top down all summer). But after a year or two of doing this, it became bothersome, so now I don't worry about it. And mine came with a cloth case for the plexiglass and if you angled it just right, it would fit into the cubby in the back.
Glen
Old 03-14-2016, 07:32 PM   #6
If I remember correctly, the cloth case that came with my windscreen was a pretty cheap looking bit of kit. If you really need a case, buy some nice fabric and have someone handy with a sewing machine make one for you.
Old 03-15-2016, 08:27 AM   #7
2003 Base 5-speed
grc0456's Avatar
I zip tie my roll bar mesh screens. Not theft proof, but at least a deterrent. The center plexiglass is not secured in any way. I have the black soft cloth bag for its storage - I wedge it behind the spare during cold weather months when the top stays up. My wife doesn't let me walk away from the car with the top down when it's warm.
Old 03-15-2016, 09:18 AM   #8
kk2002s's Avatar
+1 Zip Tie
I drilled a small hole in center wind screen to zip tie it as well.
Wasn't as a theft preventive but I was afraid of popping out on the Hwy.
Seal Grey
Old 03-15-2016, 09:37 AM   #9
2003 Base 5-speed
grc0456's Avatar
+1 Zip Tie
Good idea!
Old 03-15-2016, 10:07 AM   #10
Giller's Avatar
My centre windscreen is in place 24/7 365 days. Maybe if I lived in a big city or high crime area - but out here in small town Ontario, totally not worried about it.
Old 03-15-2016, 10:37 AM   #11
2003 Base 5-speed
grc0456's Avatar
Do you find any issues with in cabin air flow to the rear window in winter? I recall seeing that it is suggested it be taken out to not impede air flow for defrosting. I'd just as soon leave it 24/7/365.
Old 03-15-2016, 02:05 PM   #12
PaulDash's Avatar
+1 Zip Tie
No need to worry. I've tested above 200km/h and it stays put.
Past: 944 NA white '86
Present: 986 black '98
Future: 959
PaulDash is offline   Reply With Quote
